Thump when turning and accelerating.
I get a weird thump or clunk from the drivers side when the steering wheel is turned to make a right turn. It doesn't clunk when cruising into the turn, but if I accelerate from a stop or accelerate into a right turn it clunks. Started happening after replacing my clutch. Any suggestions?
Dan
Dan
i had the same problem turning left and posted a million times about it and got no help other than cv boot .. iOno tho, because it went away, only happens once in great while now.. *shrugs* i know i still need to figure it out tho
I have a clunk coming from the left wheel when making tight slow turns (i.e parking).. it clunks at a particular spot, probably after one full turn or so.. and clunks again on the way back.
its a metalic type of sound, kinda like DING CLUNK with a bit of SCRAPE in between.
any ideas? i've always thought CV but now i think its something worse, its quite loud too.
Nothing says it has to be the same thing on all your different cars, either. Drive up on ramps & look for loose bolts. Maybe loose bolts holding a subframe? Maybe loose inboard mounting points for control arms? Maybe anti-roll bar endlinks are loose?? You're each gonna have to look at all that stuff until you find something loose.
Sometimes jacking it can hide the problem. For example if a shock is getting flaky, you can jack it up & the shock will be stretched out to it's max & you can't tell it's loose. Got ramps?
Jizzmaster Zero
12
Jun 16, 2006 02:42 PM
AGPSuperstar
11
Feb 13, 2003 04:44 PM
accelerating, accellerating, axle, cbr600rr, clunk, cv, honda, m3, noise, repetitive, saab, sentr, thump, thumping, turning
