No spark DEAD CAR
Old Jan 15, 2005 | 11:15 PM
jason190's Avatar
Default No spark DEAD CAR
Here goes.......My car is at the shop getting tuned and he was tuning it, and around 6500rpms it backfired bad and the stoped running. He tried to pop the clutch to restart it and nothing. So he got it back and found out it wasn't getting any spark. It was running on all stock ingition. He hooked it up to some computer and said it was the ingition control.( inside the distributor) so we took one out of another dx distributor and still no spark. I think it could be the coil? (and he said he checked all the fuses) We never swaped it out.
Old Jan 15, 2005 | 11:17 PM
jason190's Avatar
Default Re: No spark DEAD CAR (jason190)
I mean we never swaped out the coil. And he popped out the clutch when still driving. I proof read it after posting LOL!
Old Jan 16, 2005 | 08:30 AM
Chiovnidca's Avatar
Didn't snap the t-belt did it?
Old Jan 16, 2005 | 09:48 AM
jason190's Avatar
Default Re: No spark DEAD CAR (Chiovnidca)
no. It all turns over. It's just not getting any spark. I don't know what the deal is
Old Jan 16, 2005 | 12:42 PM
DirtyDx's Avatar
i bet its the coil. when we did the swap on my friends crx we couldnt find out why it wasnt sparking. we changed the igniter and after that didnt work we did the coil.
i think that is your best bet.
Old Jan 16, 2005 | 01:25 PM
jason190's Avatar
Default Re: No spark DEAD CAR (vtiCoupe)
Yea.....I think soo too. I have to exchange it at the junk yard, and if they don't take it back then I'm gonna switch the coil.
Are coils from B16's and D's all the same?
Old Jan 16, 2005 | 09:33 PM
ReV LiMiT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason190 &raquo;</TD></TR><TR><TD CLASS="quote">Are coils from B16's and D's all the same?</TD></TR></TABLE>
nope, but i think all b series are....
Old Jan 16, 2005 | 10:44 PM
PrettyLude's Avatar
all b series coils are the same, not too sure if b and d are interchangeable
Old Jan 17, 2005 | 06:39 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason190 &raquo;</TD></TR><TR><TD CLASS="quote">... He hooked it up to some computer and said it was the ingition control.( inside the distributor) so we took one out of another dx distributor and still no spark...</TD></TR></TABLE>Maybe that means it was the CYP, CKP, & TDC sensors inside the distributor. Swapping the ignitor didn't do anything to fix these...
Old Jan 18, 2005 | 05:49 PM
jason190's Avatar
Default Re: No spark DEAD CAR (JimBlake)
We put in the the new dis. and the same thing drove a little bit and no spark. So we by passed the stock coil and hooked up the MSD and it fired right up. So it ended up blowing 2 stock coils. What do you think could be causing this? But it doesn't blow the MSD coil.
Old Feb 7, 2005 | 08:53 PM
usfsfirefighter0's Avatar
Is the wireharness arcing on the motor at all there maybe short? If not the distributor it could also be the computer try put a your ecu in a friends car with similiar swap, u can try to putt another ecu in yur car, or u can also do this with distributor. Also check check ign fuse (15 amp) in the fuse box in the dash and the engine bay ? Hopefully this works or steers u to the problem but if u find the problem please let me know ok?
Old Feb 16, 2005 | 11:59 AM
jason190's Avatar
Default Re: No spark DEAD CAR (usfsfirefighter0)
Well the car has been running fine with no problems for about a month. I was just curouis why it would go through 2 stock coils and not blow the MSD coil.
CiViCgT32
Mar 17, 2007 12:21 PM
CptCorN
Jan 17, 2005 06:33 AM
iNetForce
Feb 29, 2004 09:59 AM
BadBeck
Dec 11, 2003 05:59 PM
russian_racer
Jun 23, 2003 07:09 PM
