Vtec wont hit? searched
Old Jan 15, 2005 | 08:30 PM
dumpeDc2's Avatar
I'm a Jackass
Default Vtec wont hit? searched
k I just finnished my LSvtec I have a 99 LS with a 00b16 head on it. Im running a Ls 0bd2 to obd1 harness but I think the harness is wired for vtec so I just pined the vtec wire to to the correct spot one the engine harness. but hear is the part that im confused abought when I tryed to run the oil pressure wire on the p28 the oil pressure spot is D6 for obd1, but when I follow the wire through the jumper harness is gose to the spot right next to the obd2 oil pressure spot. wtf? so when I un-pin the wire that comes from the engine and put the new oil pressure wire in it throws a code I think it is code 90 but it might be throwing more than one. It also dosent throw anycodes when I have it hooked up without the oil pressure?
Im using this page for the diagrams
http://www.hondaswap.com/forum...29360
Old Jan 16, 2005 | 06:01 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: Vtec wont hit? searched (DumpeDc2)
any help would be good It is now throwing the code like 2sec. eveytime i start it up.. Im also running the jays racing chip
Old Jan 17, 2005 | 08:33 AM
clint g's Avatar
U need to check the ground wire thats the only thing I can think of
Old Jan 17, 2005 | 05:03 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: Vtec wont hit? searched (clint g)
ya just switch the ground wire up and its not the problem. im pritty stuck at this moment
Luke G.
Jun 20, 2010 07:22 AM
Bimmerman
Jun 15, 2005 05:23 PM
vtecb20coupe
Aug 17, 2004 08:16 AM
vtecb20coupe
Aug 17, 2004 08:12 AM
00DVPGSR
Aug 9, 2003 01:23 PM
