Question abt cam profile
Old Jan 15, 2005 | 05:59 PM
Pullig's Avatar
Default Question abt cam profile
My question is right now im wanting more power and its for an NA application but i am going turbo later on when i can get more cash together. I was jsut wondering will this cam work well with a turbo application or should i jsut stay stock cams for now and wait for the turbo. But im wanting more power now
these are Web Camshafts factory regrinds
Honda Prelude DOHC 16v ('92-97) H23a1
*Regrind
Your Cam
Part # Buy Now
@ .050 Grind # Description
35-310
$256
.390 Valve lift 230° Duration 210° Duration at 0.050 620+5°
increased mid and upper end performance. Cost per set.
Old Jan 15, 2005 | 06:46 PM
SuperSlow's Avatar
Default Re: Question abt cam profile (Pullig)
Just stick with what you got and save for your turbo.
Old Jan 15, 2005 | 07:04 PM
PirateMcFred's Avatar
I bet that the WEB cam is not cheap and Crower's stage ones are better for turbo (new cores too, not regrinds) and that duration will not only suck for turbo it will be a PITA to tune for an idle less than 1000rpm.
Pirate
Old Jan 16, 2005 | 05:25 AM
Pullig's Avatar
Default Re: Question abt cam profile (PirateMcFred)
yeha web cam regrind is $256.00 and ive already got the cores jsut debating rather more power now or jsut saving the money can anyone else give me some opinions
Old Jan 16, 2005 | 08:00 AM
I went to the WEB sie and looked around and saw what you were talking about. the duration is actually 210* at 50 thou. That should be fine for a daily driver and idle fine. I thought you were tallking about a cam with 230* at .050".
You miight have to upgrade your stock springs/retainers but I am sure that WEB can advise you on that.
Pirate
Old Jan 16, 2005 | 04:42 PM
Pullig's Avatar
BUMP
Old Jan 16, 2005 | 06:08 PM
satan_srv's Avatar
If you're really going turbo, save your money. You'll need it for the re-sleeve and turbo parts and fuel management.
JFra1357
May 6, 2007 05:33 PM
redDAinteg
May 3, 2005 09:38 PM
Rhythm Racer
Jul 16, 2003 08:14 AM
DSeriesBeeKilla
Jul 14, 2003 03:39 PM
SOHC_MShue
May 19, 2003 12:40 PM
