ALTENATOR WHINE NOISES
Old Jan 15, 2005 | 03:21 PM
UKACCORD92's Avatar
Default ALTENATOR WHINE NOISES
HI CAR AUDIOPRO... IM CALLING FROM THE UNITED KINGDOM .. IM CURRENTLY IN THE PROCESS OF INSTALLING MY CAR SYSTEM IN MY 92 ACORD AND I JUST WANTED TO COMMENT ON THE SUBJECT OF ALTERNATOR NOISE IN THE CAR'S AUDIO SYSTEM. I HAD ONCE DID AN INSTALL IN A HYUNDIA COUPE USING A ALPINE 9813 HU,JBL 1200.1 AMP + 2 12 KAPPA SUBS , INFINITY 4 CHANNEL AMP +INFINITY COMPONENTS AFTER THE INSTALL I FOUND THAT I HAD A WHINING PROBLEM I STARTED TO CHECK EVERY THING YOU COULD THINK OF EXCEPT ONE THING ... AND THATS WAS TO MOVE THE PRE OUT RCA CABLES TO ONE SIDE AWAY FROM THE UNDER DASH WIRE BEHIND THE STEREO ,WHEW ! AND THAT SOLVED THE PROBLEM .....NOW IN ONE QUESTION THAT YOU ANSWERED YOU MENTION REMOVING THE GROUND FROM THE FACTORY AND POWER WIRE TO THE AMP BUT ARE IVE HEARD OF THIS METHOD BUT ARENT YOU SUPPOSE TO HAVE THE GROUND WIRE NOT EXCEEDING NO MORE THAT THREE FEET LONG ? I WILL BE THIS SUMMER INSTALLING MY SYSTEM WHICH CONSIST OF A ALPINE 8794 RB HU,AUDIO CONTROL MATRIX LINE DRIVER , AUDIO CONTROL EQS, JBL BPX SERIES 2200.1 MONO AMP ( I NEED YOU INPUT ON THE AMP ) PX 300.4 RUNNING THE POWER SERIES 61/2 COMPONENTS, 2 INFINITY PERFECT 10 VQS OR 2 GTI W12S SUBS I ...SPEAKING OF AUTTUNATION WHATS THAT AS IVE GOT THE 61/2 COMPONENTS IN THE DOOR RUNNING TWO TWEETERS FREOM THE CROSSOVER AT -3DB IS THIS A OK SETTING ? ALSO LAST QUESTION SHOULD I BE USING 2 4GAUGE WIRES AND A OPTIMA YELLOW BATTERY ,,,, I HOP I DIDNT BORE YOU WITH MY QUESTION
Old Jan 15, 2005 | 10:56 PM
..::91TEG-G2::..'s Avatar
Default Re: ALTENATOR WHINE NOISES (UKACCORD92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UKACCORD92 &raquo;</TD></TR><TR><TD CLASS="quote">HI CAR AUDIOPRO... IM CALLING FROM THE UNITED KINGDOM .. IM CURRENTLY IN THE PROCESS OF INSTALLING MY CAR SYSTEM IN MY 92 ACORD AND I JUST WANTED TO COMMENT ON THE SUBJECT OF ALTERNATOR NOISE IN THE CAR'S AUDIO SYSTEM. I HAD ONCE DID AN INSTALL IN A HYUNDIA COUPE USING A ALPINE 9813 HU,JBL 1200.1 AMP + 2 12 KAPPA SUBS , INFINITY 4 CHANNEL AMP +INFINITY COMPONENTS AFTER THE INSTALL I FOUND THAT I HAD A WHINING PROBLEM I STARTED TO CHECK EVERY THING YOU COULD THINK OF EXCEPT ONE THING ... AND THATS WAS TO MOVE THE PRE OUT RCA CABLES TO ONE SIDE AWAY FROM THE UNDER DASH WIRE BEHIND THE STEREO ,WHEW ! AND THAT SOLVED THE PROBLEM .....NOW IN ONE QUESTION THAT YOU ANSWERED YOU MENTION REMOVING THE GROUND FROM THE FACTORY AND POWER WIRE TO THE AMP BUT ARE IVE HEARD OF THIS METHOD BUT ARENT YOU SUPPOSE TO HAVE THE GROUND WIRE NOT EXCEEDING NO MORE THAT THREE FEET LONG ? I WILL BE THIS SUMMER INSTALLING MY SYSTEM WHICH CONSIST OF A ALPINE 8794 RB HU,AUDIO CONTROL MATRIX LINE DRIVER , AUDIO CONTROL EQS, JBL BPX SERIES 2200.1 MONO AMP ( I NEED YOU INPUT ON THE AMP ) PX 300.4 RUNNING THE POWER SERIES 61/2 COMPONENTS, 2 INFINITY PERFECT 10 VQS OR 2 GTI W12S SUBS I ...SPEAKING OF AUTTUNATION WHATS THAT AS IVE GOT THE 61/2 COMPONENTS IN THE DOOR RUNNING TWO TWEETERS FREOM THE CROSSOVER AT -3DB IS THIS A OK SETTING ? ALSO LAST QUESTION SHOULD I BE USING 2 4GAUGE WIRES AND A OPTIMA YELLOW BATTERY ,,,, I HOP I DIDNT BORE YOU WITH MY QUESTION</TD></TR></TABLE>
take the caps lock off man
Old Jan 16, 2005 | 06:16 AM
cd5_2NR's Avatar
Default Re: ALTENATOR WHINE NOISES (..::91TEG-G2::..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..::91TEG-G2::.. &raquo;</TD></TR><TR><TD CLASS="quote">
take the caps lock off man</TD></TR></TABLE>
do it...DO IT NOW...
Old Jan 18, 2005 | 05:35 AM
UKACCORD92's Avatar
Default Re: ALTENATOR WHINE NOISES (cd_5TUNR)
is that your answer ......? dont bother replying ok, if it not about my question thank u
Old Jan 18, 2005 | 08:15 AM
loki2323's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UKACCORD92 &raquo;</TD></TR><TR><TD CLASS="quote">is that your answer ......? dont bother replying ok, if it not about my question thank u</TD></TR></TABLE>
You type in caps and expect somone to read thru that mess you call a post? Then with your 3 posts you are telling someone don't bother?
have a nice day....friggin noob
Old Jan 18, 2005 | 08:36 AM
YAMAHAtrueracer's Avatar
Default Re: ALTENATOR WHINE NOISES (loki2323)
There are already multiple Threads about alternator whine that are still current, just look at one of those instead of posting another one.
98civdx
Audio / Security / Video
Jan 3, 2012 09:12 PM
stackz
Oct 17, 2006 01:12 PM
MisterHYBRID
Sep 22, 2003 08:45 PM
JOMO
Jun 17, 2003 09:22 PM
beef3000
May 28, 2003 05:18 PM
