Inner Transmission Oil Seal
I'm trying to replace the drivers side axle seal on the transmission in my 91 CRX Si. How deep do you set the seal? Or does it set flush as in the picture below and the axle when seated makes the seal on the inside? Its been a while since I removed the old one and I can't remember so any help would be greatly appreciated!
(You can click on the picture for a larger picture.)
Thanks a million for the reply! So basically the picture is correct then?
