High idle - reason?
Old Jan 15, 2005 | 12:20 PM
KetteringITR's Avatar
Default Revving a bit high.....whats happening?
Starting a couple weeks ago, the ITR started to act a bit strange. When i start the car, it will idle at about 1600 rpms and then once it warms up, it will idle at about 1200 rpms. Now granted it is really friggin cold where i am right now but even so, it used to idle at 600-800 rpms warm. I checked the spring return on the throttle and it snaps back and makes a good metal to metal sound so i dont think my throttle plate is dirty. I could always take off the intake and check. Just wanted some other opinions as to what could be goin on. Thanks for your help.
Old Jan 15, 2005 | 12:28 PM
Willard's Avatar
Default Re: Revving a bit high.....whats happening? (KetteringITR)
lights on?
heater fan on? (that is my guess)
there are a few sensors that bump the revs up.
-power steering pressure sensor
-ELD (engine load dector)
-VSS
Old Jan 15, 2005 | 12:41 PM
Default Re: Revving a bit high.....whats happening? (Willard)
If you could, could u explain what those three u listed were and are they easy checks. And also started relatively recently so im not sure what would cause it
Old Jan 15, 2005 | 04:04 PM
ZygSpeed's Avatar
Thermostat could be stuck open.
Old Jan 15, 2005 | 04:13 PM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">-power steering pressure sensor
-VSS</TD></TR></TABLE>
p/s = when the idle is low turn the wheel from side to side (the idle will come up)
ELD (engine load detector) = turn the high beams on and crank the heater fan on (the idle will come up)
VSS (vehicle speed sensor) = when you are rolling the idle will be above normal to help prevent stalling. once you come to a stop the idle will drop back down to normal.
Old Jan 15, 2005 | 06:55 PM
TypeR864's Avatar
I have also had the same problem and it only happens when it is cold outside. It's only like 12 degrees here but anytime its below freezing it seems to do this until the car warms up. What could it be b/c it's nothing anything previously listed?
Old Jan 16, 2005 | 08:53 AM
VSS (vehicle speed sensor) = when you are rolling the idle will be above normal to help prevent stalling. once you come to a stop the idle will drop back down to normal.</TD></TR></TABLE>
Well the problem is my idle is up and i dont know why and its not because of either of the first two. And its not the VSS because this is all while im stopped.
Old Jan 18, 2005 | 03:53 AM
chameleon's Avatar
check your coolant, the idle will do exactly what is happening to you if you are low on coolant or there are air bubbles in the system. when the car is cold open the radiator up and fill it up. check to see where u are leaking from.
90Rexx
Jul 2, 2008 08:53 AM
90Rexx
Jun 29, 2008 09:35 PM
mad21kid
Feb 18, 2008 12:52 PM
PINKS
May 29, 2006 10:26 PM
choutreux
Apr 18, 2004 07:20 AM
