Tranny problems in 90 si hatch
Old Jan 15, 2005 | 11:37 AM
ComputerJLT's Avatar
Default Tranny problems in 90 si hatch
ok my transmission is starting to flake on me. It was fine up until about 2 weeks ago when I think i accidently used the shifter as an oh **** handle... oops.
I'm not sure though because the problems didnt start happeneing until a day or two later.
The problems are:
-2nd gear pops out on decel @ speed (checked shifter linkage; didnt see any obvious binds)
-there is a distinct metal grinding/whining noise in 3rd+ gears (bearing backing out maybe?) My old 4spd junk tranny made this same noise but all gears were useable and the noise was 40x louder.
-No grinds in any gear; all shifts are smooth and fall in place as the revs match.
I'm pulling my motor probably today or tomorrow to get ready for my latest engine swap (motor in my sig) and since i'm waiting on spark racing's sorry *** to quit dicking around and send me my rods i'll have plenty of time to pull the trans apart and take a look. Only problem is i have no idea what to look for.
Should i be looking for backed out bearings; bent/proken forks; missing clips; etc etc?
Old Jan 15, 2005 | 03:21 PM
Default Re: Tranny problems in 90 si hatch (ComputerJLT)
anyone have an idea?
Old Jan 15, 2005 | 04:13 PM
Brick Top's Avatar
have u checked the fluid?
could be low or just need a change.
Old Jan 15, 2005 | 09:26 PM
Default Re: Tranny problems in 90 si hatch (efhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efhatch &raquo;</TD></TR><TR><TD CLASS="quote">have u checked the fluid?
could be low or just need a change.</TD></TR></TABLE>
i just put the tranny in not 1500mi ago so it has fluid;
it hasn't leaked that i know of but i'll check it when its out i guess
Old Jan 15, 2005 | 11:13 PM
FIGARILA's Avatar
check the clearance on the shifter fork.
Old Jan 16, 2005 | 02:49 AM
Blackzc's Avatar
Default Re: Tranny problems in 90 si hatch (FIGARILA)
^ yeah mabye you bent it, while jammin on it
Old Jan 16, 2005 | 02:03 PM
Default Re: Tranny problems in 90 si hatch (vtechoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtechoe &raquo;</TD></TR><TR><TD CLASS="quote">^ yeah mabye you bent it, while jammin on it</TD></TR></TABLE>
is that fixable or would i need a new fork?
also whats up with the bearings? are they worn or backed out? or both
i guess i'll have t ofind out when i pull the trans out
Old Jan 16, 2005 | 10:51 PM
anyone else have anything before i rip the thing out?
hmoobhero
Aug 9, 2009 01:02 PM
Matt (SG)
Jun 5, 2008 05:06 PM
Dkober101
Mar 5, 2008 02:34 PM
