Disconnecting Vafc
Old Jan 15, 2005 | 10:36 AM
bill clinton jr.'s Avatar
Default Disconnecting Vafc
I have searched thoroughly to find an answer to this question but no luck. I dont have a manual and the vafc was hooked without me there. So is there anything I need to do to disconnect this or is it just merely removing the wires and resplicing them if needed? Any help would be greatly appreciated.
Old Jan 15, 2005 | 11:53 AM
IN VTEC's Avatar
Default Re: Disconnecting Vafc (bill clinton jr.)
All of the wires but the VTEC and MAP sensor wires can simply be cut since they're wired in parallel. The VAFC is wired in series with the VTEC and MAP wires, so you have to rejoin those or it won't run with a MAP sensor input.
Old Jan 15, 2005 | 01:57 PM
I will try that. Thanks
Old Jan 15, 2005 | 02:27 PM
IN VTEC's Avatar
Default Re: (bill clinton jr.)
Take a look at the VAFC installation manual @ http://www.apexi-usa.com
Remember that you need to rejoin wires of the same color together. If you can keep that in mind, it'll make it a hard to mess up. You may need to solder and heat shrink an extra bit of wiring to give you more slack.
WTR
Jan 2, 2006 09:02 AM
EFB16aJP
Oct 25, 2005 12:38 PM
smkngsr
May 10, 2004 12:17 AM
iam7head
Jul 14, 2003 04:26 PM
2000blacksi
Aug 27, 2002 10:28 AM
