Messed up IdLe.....NO cel code
Old Jan 15, 2005 | 10:36 AM
crexer's Avatar
Default Messed up IdLe.....NO cel code
Got my b16 swap in my crx finally done and its got a weird idle. At first It threw code 14 IACV and I realized that it wasnt plugged in. I have cleaned the screen on that valve and the idle still bounces from like 1,000 to 1500 rpms'. NO codes anymore but it still does this. I have bled the coolant system several times and that did seem to bring it down a bit. What about the adjuster screws on the TB? How do you go about adjusting these? What other ideas do you guys think this might be?
BTW, its a b16a obd0, pr3 ecu
Old Jan 15, 2005 | 11:32 AM
Mr_CRX's Avatar
Default Re: Messed up IdLe.....NO cel code (crexer)
Have you tried swapping out for a known-good IACV? I had this same problem, fluctuating idle, no codes, cleaned it and it still did it. When I swapped it out for a different one, all was fixed.
Old Jan 15, 2005 | 11:45 AM
PHOBIA's Avatar
the screw on your throttle body? you just stick a screw driver in there and turn it in to lower the idle or twist it out further to raise it.
Old Jan 15, 2005 | 11:51 AM
RCautoworks's Avatar
Did you reset you ecu and let the car idle ( don't touch anything ) for 10 mins after wards ( or until operating temps have been achieved )
Old Jan 15, 2005 | 12:29 PM
untitled's Avatar
The problem here is the fitv... Take it apart and screw the screw in and it wont happen anymore. do a search for FTIV...
Old Jan 15, 2005 | 12:59 PM
87b16crx's Avatar
Default Re: Messed up IdLe.....NO cel code (untitled)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by untitled &raquo;</TD></TR><TR><TD CLASS="quote">The problem here is the fitv... Take it apart and screw the screw in and it wont happen anymore. do a search for FTIV...</TD></TR></TABLE> thats what i would have to say. it is the little valve UNDER your throttle body. it should have two hoses going into it and three bolts holding it on. take off the cap on the end and screw the white peice all the way in tight. that will fix the problem.
Old Jan 15, 2005 | 01:04 PM
untitled's Avatar
Default Re: Messed up IdLe.....NO cel code (87b16crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 87b16crx &raquo;</TD></TR><TR><TD CLASS="quote"> thats what i would have to say. it is the little valve UNDER your throttle body. it should have two hoses going into it and three bolts holding it on. take off the cap on the end and screw the white peice all the way in tight. that will fix the problem.</TD></TR></TABLE>
Sure will. The only thing that is it wont hold at 2k rpm when you start it up cold, but if you dont drive in the winter or live in a warm state it really doesnt matter...
Old Jan 15, 2005 | 09:46 PM
PHOBIA's Avatar
to see if that is really the problem,temporarliy block it off with some thing.loosen it up and slide a piece of a ceral box in there and tighten it down,it will most likely go away.i have had to replace several of these *******.
Problemo
Jan 29, 2006 04:16 PM
crexer
Jan 20, 2005 08:09 AM
Glocked1
12
Jan 22, 2004 08:13 PM
