Valve Stem Seals Replacement
Old Jan 14, 2005 | 10:44 PM
SynTeg's Avatar
Default Valve Stem Seals Replacement
I just hot tanked my zc head with retainers,springs, etc. still on and i'm just wondering if it is necessary to replace the valve stem seals. Also is there any other things I should do to the head before putting it back on the block? Thanks
Old Jan 15, 2005 | 08:24 AM
mmuller's Avatar
Mad Scientist
Default Re: Valve Stem Seals Replacement (SynTeg)
yes, replace the seals.
Old Jan 15, 2005 | 09:08 PM
SynTeg's Avatar
Is there anything else I could replace?
Old Jan 15, 2005 | 10:59 PM
PrettyLude's Avatar
valve guides
Old Jan 16, 2005 | 05:12 PM
FLOWZILLA's Avatar
Default Re: (SynTeg)
THE BEST THING TO DO IF YOU WANT TO DO IT RIGHT IS TO RECONDITION THE HEAD.. (EXAMPLE.. TEAR DOWN REFACE VALVES, VALVE JOB, RESURFACE, INSTALL NEW SEALS,AND REASSEMBLE) THGAT WAY THERE WONT BE ANY SURPRISES PLUS AN EFFICENT HEAD WILL RUN MUCH BETTER.. AND SINCE YOU ARE GETTING A VALVE JOB, YOU CAN PROBABLY GET SOME MORE POWER OUT OF IT IF YOU HAVE ANY QUESTIONS FEEL FREE TO ASK..
dominate9
Apr 14, 2020 02:10 PM
80 dolla crx hf
Sep 8, 2014 01:28 PM
BigC-ivic
Oct 22, 2004 02:46 PM
TeamCracka
Feb 17, 2004 06:33 PM
skribblah
Jun 30, 2003 08:10 PM
