Energy Suspension install instructions
Old Jan 14, 2005 | 10:00 PM
Ballade's Avatar
Default Energy Suspension install instructions
Hearing conflicting install instruction on Energy Suspension master kit.
is the outer sleeves on the lower control arms/ upper control arms/trailing arms/ left in or removed to install bushings?
Thanks guys
Old Jan 15, 2005 | 07:50 AM
Ballade's Avatar
Default Re: Energy Suspension install instructions (Ballade)
Bump
Old Jul 27, 2005 | 11:02 PM
BoOsTiN Dc2's Avatar
bump... what is the hardest part of installing the "kit"
Old Jul 29, 2005 | 10:34 PM
stumpyf4's Avatar
Front and Rear Lower control arms the outer bushing can is removed and discarded. Not sure about the front upper control arms but I think they don't have a outer bushing can to remove. Can't say either way for the trailing arms.
Do some research on suspension binding casued by the ES bushings... you may want to rethink installing the trailing arms bushing and certain parts of the front lower control arm.
Got mine partially installed, shifter, rear shock, steering rack. Plan to do the front upper soon followed by the rear lower arms and then front lower. Taking my time so I don't have any down time with the car.
kasperxtcy
Suspension & Brakes
Mar 24, 2010 09:14 AM
Locrien
Feb 21, 2010 12:17 PM
Loserkidwac
Jul 5, 2006 11:57 AM
RacerBoy
12
Apr 3, 2003 08:06 AM
