b16a idling like poo
Old Jan 14, 2005 | 01:26 PM
blurrrcivic94's Avatar
Default b16a idling like poo
After I swapped my edelbrock Victor x IM for a Skunk2 my idle started acting wacky. It idles at about 1500, and after I blip the gas a little bit, the rpms will drop down to 800-900 then immediately jump back up to 1500. Does anyone have any ideas?
Old Jan 14, 2005 | 01:27 PM
93CX's Avatar
Default Re: b16a idling like poo (blurrrcivic94)
could be some kind of gasket or vaccum leak.
Old Jan 14, 2005 | 01:30 PM
poison's Avatar
vacuum leak. definitely.
Old Jan 14, 2005 | 01:32 PM
Default Re: b16a idling like poo (poison)
the car hesitates really badly when I drive it too.. like if I just barely depress the throttle pedal the car wants to jerk back and forth till i give it more throttle..
poison's Avatar
vacuum leak..
Old Jan 14, 2005 | 01:39 PM
thanks i'll go look at it
Old Jan 14, 2005 | 01:41 PM
AutoXer's Avatar
Spray carb cleaner all around where the leak could be. When the idle jumps, you've found your leak location.
Old Jan 16, 2005 | 11:15 AM
jdmjohnny's Avatar
i dont think its vaccum...try ur fast idle..take it off inside should b a plastic screw..tighten it all the way that should fix it..
apbtwhiskey
Mar 20, 2013 09:39 PM
92DAB16A
Feb 1, 2012 04:42 AM
ge_ej1
Jan 29, 2008 05:09 PM
Irish Integra
Mar 31, 2005 02:30 PM
rtiadnoh
Feb 15, 2004 12:41 PM
