coilover set up or spring set up?
Old Jan 10, 2002 | 01:39 PM
VTssblueEC's Avatar
New User
Default coilover set up or spring set up?
which one whould you recommend?
pros and cons of both please.
Old Jan 10, 2002 | 02:01 PM
Crazydave's Avatar
Default Re: coilover set up or spring set up? (VTssblueEC)
coilover
adjustable ride height and cross weight you can custom order the spring rates you want ... you can have a really bad setup or a really really good setup
springs stuck with what ever ride hieght you get.... no cornerweighting no messing with it either (which mean you can't screw it up (no pun intended) you get a decent setup every time
Old Jan 10, 2002 | 04:33 PM
BTR ALL MOTOR's Avatar
if you are going for more performance, get coil overs, you will sacrifice the better ride, but coil overs wont "sink" of the line when you launch......springs have a tendancy to sink off the line which in turn equals a loss of horespower......the same thing when shifting, the stiffer the suspension the less the car will sink and the more horsepower you will get to the wheels
Old Jan 10, 2002 | 05:29 PM
VTssblueEC's Avatar
New User
Default Re: coilover set up or spring set up? (BTR ALL MOTOR)
Okie,, I think I'm going to get the comptech sports 1.3" drop. got idea to keep the stock shocks?
what shocks should I get?
Freshdot
Suspension & Brakes
16
Mar 28, 2013 12:04 PM
HONEG6Freak
Suspension & Brakes
Dec 9, 2006 02:33 PM
evolvedAP1
Jul 8, 2006 06:29 PM
jsnm
Suspension & Brakes
Jul 28, 2005 09:42 AM
KiD Fr0m Da 516
Feb 12, 2004 12:53 PM
