noob question about rear main seal (searched)
Old Jan 14, 2005 | 07:47 AM
Do_Ster's Avatar
Default noob question about rear main seal (searched)
ok sorry for the newbie post guys but here it goes. do i need to remove the tranny to replace the rear main seal on a d15z1? would i be able to replace the seal by just removing the oil pan? never took a tranny off before so i'm a bit intimidated and want to know if there was an easier way. i've also searched already and there were some posts where the tranny was off and some posts where people stated to remove the pil pan, but i'm not sure if they meant remove the oil pan and/or tranny. tia
Old Jan 14, 2005 | 07:55 AM
ap1amor's Avatar
Default Re: noob question about rear main seal (ntogethernow)
yea, you'll need to remove the transmission to access the rear main seal. Good Luck!
Old Jan 14, 2005 | 08:00 AM
Marauder's Avatar
Default Re: noob question about rear main seal (humbleHX)
The rear main seal is a solid ring around the crankshaft. There's no way to get it out without getting the flywheel off first.
You have to remove the tranny and flywheel and then you can pry out the seal. Its one of those cheap things to do whenever you do a clutch change.
Old Jan 14, 2005 | 08:23 AM
Do_Ster's Avatar
thanks for the quick responses. now that i know i have to take the tranny off, you guys got any tips for someone taking off their tranny for the first time? thanks again
Bobby_Budds
May 31, 2010 07:10 AM
nplsdvr
18
Jun 29, 2008 04:45 PM
JDMPower98cp
Jan 2, 2006 12:11 AM
Cuong-nutz
Oct 5, 2005 10:28 AM
0ptimus prime
12
Jul 18, 2004 01:29 PM
