Suspension & Brakes Theory, alignment, spring rates....
Can the stock spring be decompress whil its still attached to the car?
Old Jan 13, 2005 | 10:08 PM
seeeya04's Avatar
Default close
close
Modified by seeeya04 at 5:09 PM 1/15/2005
Old Jan 13, 2005 | 10:16 PM
Ti3d in's Avatar
Default Re: Can the stock spring be decompress whil its still attached to the car? (seeeya04)
No way it'll work.
Old Jan 14, 2005 | 03:38 AM
00R101's Avatar
Perhaps you could use a jack to push the suspension up while its on jack stands and then install spring compressors while its still on the vehicle. But there is no advantage and you may not get the spring/shock out since its a tight fit without the compressor. Also it seems kinda dangerous to me. Sounds like you are trying to figure out a way to avoid spring compressors. No way.
Old Jan 14, 2005 | 05:30 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seeeya04 &raquo;</TD></TR><TR><TD CLASS="quote">i guess what iam saying it like the bolts under the hood can i undo the bolt and ect so it will decompress..</TD></TR></TABLE>
What are you trying to do?
Just buy a spring compressor from autozone... $20
Old Jan 14, 2005 | 10:31 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Can the stock spring be decompress whil its still attached to the car? (Ti3d in)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ti3d in &raquo;</TD></TR><TR><TD CLASS="quote">No way it'll work. </TD></TR></TABLE>
How do you figure that? If you removed the nuts that hold the shock to the upper hat, then raised the car w/ your jack, it will definently decompress the spring all the way. Now weather or not that is safe, well, I wouldn't try it.
Oh yeah, how the hell would you get the spring back in there after you did that? Just rent the spring comrpessor. It's free!!!
Old Jan 14, 2005 | 11:36 AM
1fastVX's Avatar
Default Re: Can the stock spring be decompress whil its still attached to the car? (94eg!)
I have tryed doing it while on the car...I guess I was being dumb and I was trying to rush. Big mistake!! When the spring decompresses it make it virtually impossible to get the shock and spring off the car. I spent a lot of time tying to get the shock back together so I could get it off the car. It was not fun!
John
Old Jan 14, 2005 | 12:03 PM
Tyson's Avatar
Default Re: Can the stock spring be decompress whil its still attached to the car? (1fastVX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fastVX &raquo;</TD></TR><TR><TD CLASS="quote">I have tryed doing it while on the car...I guess I was being dumb and I was trying to rush. Big mistake!! When the spring decompresses it make it virtually impossible to get the shock and spring off the car. I spent a lot of time tying to get the shock back together so I could get it off the car. It was not fun!
John</TD></TR></TABLE>
exactly. yes you can do it like 94eg said. but with stock springs, theyre so long and preloaded that even when you loosen the top nut, theres not enough travel allowed to remove the shock from the fork. its possible, but not easy, not safe (im not talking death, but i came close to damaging my fingers).
when you are dealing with aftermarket lowering springs or adjustable springs, the length of the springs isnt an issue and it makes working wit hthe suspension really easy. but when taking off stock springs, use a spring compressor and remove it off the car.
Old Jan 14, 2005 | 03:02 PM
seeeya04's Avatar
Default Re: Can the stock spring be decompress whil its still attached to the car? (Tyson)
No iam saying you will deassemble the things you will need to deassemble to get to the spring but ..you just undo the bolts and jack the car up to decompress the spring ..
Old Jan 14, 2005 | 03:49 PM
Tyson's Avatar
you must be misunderstanding.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seeeya04 &raquo;</TD></TR><TR><TD CLASS="quote">No iam saying you will deassemble the things you will need to deassemble to get to the spring but ..you just undo the bolts and jack the car up to decompress the spring ..</TD></TR></TABLE>
thats what im saying, just try it your self then if you dont understand. it will be a bitch to disassemble if you are taking out stock springs.
Old Jan 15, 2005 | 10:07 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
use the following method ONLY if you are swapping out stock springs for lowering springs. i am not held responsible for anything you do. that being said, here's the ghetto method that works if you're safe about it and follow all the steps.
1.) Remove the lower control arm.
2.) Remove the strut fork.
3.) Remove the axle.
4.) Keep your body away from the side of the car you are working on, and remove the top nut under the hood that holds the shock and spring together. You should hear a loud noise, which of course is the shock and spring hitting the ground. VOILA! They're now apart, and you're not dead.
To reinstall with lowering springs, reassemble the strut assembly with the fork, rebolt the lower arm to the frame, and the strut to the lower arm. Jack up ther lower arm until the top of the strut rod pops through the strut mount under the hood, and reattach the nut securely. Take the lower arm back off, and reinstall the axle. Reinstall the lower arm, and you're done.
Old Jan 15, 2005 | 11:20 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (MugenDude)
You can always be lazy and remove the spring by laying the entire assembly on the ground and loosening the nut past the last couple threads via a breaker bar that puts you far away from the strut and a cardboard box to catch the pieces in. The spring will rocket that **** off like a bomb, but you will have saved yourself a trip to autozone .
I won't lie. I've done it before .
Old Jan 15, 2005 | 11:22 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenDude &raquo;</TD></TR><TR><TD CLASS="quote">1.) Remove the lower control arm.
4.) Keep your body away from the side of the car you are working on, and remove the top nut under the hood that holds the shock and spring together. You should hear a loud noise, which of course is the shock and spring hitting the ground. VOILA! They're now apart, and you're not dead. </TD></TR></TABLE>
Thats alot more work than just using a ffing spring compressor.....
Old Jan 15, 2005 | 11:38 AM
382548's Avatar
tee hee....sux doin suspension work with a lift huh! sorry woday!
Old Jan 15, 2005 | 11:39 AM
382548's Avatar
Default Re: (382548)
i mean without a lift*
alscrx
Honda Civic (2001 - 2005)
Mar 25, 2008 07:09 PM
InvaderTrax
Nov 12, 2005 02:10 PM
LBBP R
Honda S2000
Jul 31, 2005 10:22 PM
D3U1LT
10
Jan 12, 2005 12:20 PM
b18hatch
Sep 16, 2003 05:09 PM
