white smoke after swap???
Old Jan 13, 2005 | 10:00 PM
93FastLs's Avatar
Default white smoke after swap???
i just swapped a 92 cx motor into a 93 lx 4dr now when i run the car there ALOT!!!!!!!!!!!! white smoke and the car bogs once it starts going around 10mph do i have one of the lines switched somewhere. *note* running lx ecu and o2 sensor is not hooked up
Old Jan 13, 2005 | 10:56 PM
Forward Motion's Avatar
Default Re: white smoke after swap??? (93FastLs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93FastLs &raquo;</TD></TR><TR><TD CLASS="quote">i just swapped a 92 cx motor into a 93 lx 4dr now when i run the car there ALOT!!!!!!!!!!!! white smoke and the car bogs once it starts going around 10mph do i have one of the lines switched somewhere. *note* running lx ecu and o2 sensor is not hooked up </TD></TR></TABLE>
pull dipstick see if the oils milky looking. the previous motor could have a bad headgasket. BTW why a Cx motor?
Old Jan 15, 2005 | 04:36 PM
93FastLs's Avatar
i had the motor in my garage and my friend just blew his motor, so, he needed something before winter was over so it was better then nothing. the cx was taken out of my cousins car, cause it was replaced for a c5 and there werent any leaks anywhere.i also thought it was a head gasket..
Old Jan 15, 2005 | 10:37 PM
engine_runner's Avatar
Default Re: (93FastLs)
do a exhaust gas test on the coolant to be sure the head gas. isn't leaking
the enine bogs because it has no sense in knowing its mixture air to fuel
whether it should run the engine lean or rich
also i suggest to run the ecu for that engine.
Old Jan 18, 2005 | 03:12 PM
93FastLs's Avatar
t-t-t
G00BER
Appearance Build Threads
May 14, 2009 09:19 PM
neocrynym
15
Jul 30, 2004 09:11 PM
trooper0641
40
May 11, 2004 09:38 AM
riceburnah
Jun 1, 2003 05:06 PM
riceburnah
May 31, 2003 08:13 PM
