Idle problem JDM B16
Old Jan 13, 2005 | 08:35 PM
FOOLINJECTOR's Avatar
Default Idle problem JDM B16
I have an EG coupe. It ran fine for the longest time but then it started idling kinda high (2600). Well now it does th 1000-2900 jump at idle. Only does this when the car is warm. It idles at 3000 when it is cold. Any help would be apreciated. And the block code is just B16. Thanks
Old Jan 14, 2005 | 05:28 AM
Default Re: Idle problem JDM B16 (FOOLINJECTOR)
anybody?
Old Jan 14, 2005 | 07:14 AM
Filthy Focker!'s Avatar
A couple of questions for you:
1. Does it want to stall at all?
2. Can you let the idle go lower like let's say by going slower than the gear will permit?
3. Any codes come up?
4. ANy hesitation at all?
fs
Old Jan 14, 2005 | 07:40 AM
jdmjohnny's Avatar
my friend has the same car same motor...if u have fast idle..take off ur throttle body..and there should b a plastic screw turn it all the way until its tight..that should fix it buddy
Old Jan 14, 2005 | 04:31 PM
Default Re: Idle problem JDM B16 (jdmjohnny)
yea say 30 in 5th, let of the gas and the car still wants to speed up no up down idle. No hesitation really. CEL isn't on but i will go check for codes. Im going to go check for that little plastic screw and check codes, Thanks guys for helping a newbie
Old Jan 14, 2005 | 04:35 PM
jbell's Avatar
https://honda-tech.com/zerothread?id=1110077
Old Jan 14, 2005 | 09:58 PM
Default Re: (jbell)
Thanks guys. I tightened that screw and, there was a canister on the bottom of the TB, well i took it apart because it sounded like something was lose inside and the threaded piece of plastic that has like a plunger in it wascompletely unscrewed. so i screwed it bach in and reassymbled everything and it runs great now. Even got a chance to clean the TB while I had it off. Killed two birds with 1 stone. That ide was about to drive me nuts. Thanks again. -nick
Old Jan 16, 2005 | 11:19 AM
jdmjohnny's Avatar
Default Re: (FOOLINJECTOR)
told ya ..happens to a lot of b series came across them a loooooooooot man
k2day
Nov 19, 2011 09:38 PM
bradabu
Jun 28, 2011 04:03 PM
jdmstyleg
Oct 15, 2009 06:55 PM
Mentat Ghola
Apr 6, 2004 03:15 PM
