Installing DC SPORTS Rear lower sway bar on 92 Hatch, PLEASE HELP
Old Jan 13, 2005 | 06:39 PM
Hatch It's Avatar
Default Installing DC SPORTS Rear lower sway bar on 92 Hatch, PLEASE HELP
Thanks
Modified by Hatch It at 11:57 PM 1/13/2005
Old Jan 13, 2005 | 06:54 PM
BOOSTACCRD's Avatar
It's pretty simple just have a friend who knows more than you over and help you.
Well, you don't even need it so just sell it
Old Jan 13, 2005 | 06:56 PM
Tad's Avatar
Tad
Default Re: (BOOSTACCRD)
i didnt know dc made a rear swaybar
civictildeath's Avatar
Default Re: Installing DC SPORTS Rear lower sway bar on 92 Hatch, PLEASE HELP (Hatch It)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch It &raquo;</TD></TR><TR><TD CLASS="quote">Do i need the little metal brackets? I think there for ABS wiring...? </TD></TR></TABLE>
yes you need them but not for ABS it around the sway bar and connects on the LCA bolts toward the center of the car. there is a pic of it on here somewhere ill look for it
Hatch It's Avatar
Why dont i need it??? Are you new to this forum? Maybe thats why you said that....
Hatch It's Avatar
Default Re: (Hatch It)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">
I appreciate that alot man, thanks
Old Jan 13, 2005 | 07:18 PM
dohcdelsol's Avatar
You need different LCA's. Your stock 92 lca's arent drilled for a sway bar. Get a 94-01 gsr set and you will be good. Or an aftermarket brand. SRRs
Their are 3 bolts holding the Lca's in. ONe to the lower subframe, one for the strut, and one to the hub part. They are a bitch to get out be aware. Might want to invest in a torch. Soak em in PB Blaster or something of that nature.
Old Jan 13, 2005 | 07:38 PM
Hatch It's Avatar
Default Re: (dohcdelsol)
Thanks
Modified by Hatch It at 11:58 PM 1/13/2005
Old Jan 13, 2005 | 07:43 PM
turbo_ef9's Avatar
sorry bro but that is a lower tie bar.. the lil black brackets on the end of the tie bar bolt up to the inner lca bolts.. shouldn't take more than 15 mins.. really easy.. u can adjust the length of the bar to tighten it up
idriveadelsol7
Jul 7, 2005 12:07 AM
Integra21
Feb 16, 2005 07:06 PM
gaydm
10
Dec 2, 2004 10:35 PM
hmongboyLS
20
Jul 31, 2004 02:18 PM
GReddy SI
Nov 15, 2003 12:28 PM
