rear sway bar
rear sway bar
i took off my OEM rear sway bar off of my 00 integra and now my cousin is asking if he can have it for his 97 civic ex... would it bolt on with no problem?... also can he use the integra endlinks on the civic or would he have to get some other ones?... thanks
Re: (B16Drag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Drag »</TD></TR><TR><TD CLASS="quote">why dont you just try it and let us know. I took my bros rear 95 integra DC sway bar and it fit fine in my sol</TD></TR></TABLE>
dc sports doesn't make sway bars they make tie bars though.
the 96+civic have the hole for the sway bar mount's.
Re: (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">
the 96+civic have the hole for the sway bar mount's.</TD></TR></TABLE>
thats what i thought... the 96+ do have mounting holes so i wondered if it would fit
New User
dc sports doesn't make sway bars they make tie bars though.</TD></TR></TABLE>
i think he was referring to the chassis code, dc
Re: (hmongboyLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmongboyLS »</TD></TR><TR><TD CLASS="quote">
thats what i thought... the 96+ do have mounting holes so i wondered if it would fit</TD></TR></TABLE>
yup, almost 100% positive that the 96+ civic's except the 99-00 si's do not have the mounting holes
Re: (Sijray21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sijray21 »</TD></TR><TR><TD CLASS="quote">so you just need the endlinks for the sway bar in the poster's case?</TD></TR></TABLE>
yup (99-00 SI endlinks)
Re: (JDMar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMar »</TD></TR><TR><TD CLASS="quote">you cant use 99-00 Si endlinks with an integra rear swaybar</TD></TR></TABLE>
Do you have any info to back this up?
I have a 22mm ITR sway bar mounted with SI endlinks onto my stock EJ LCAs....so im 100% sure SI endlinks work with Integra swaybars.
Re: (Built2Spill)
[QUOTE=Built2Spill]
[QUOTE]
I tried putting Si endlinks on a 95 LS rear swaybar but the threaded part on the endlink was too short, so i was jus speakin from experience.
[QUOTE]
Re: (jdm93cx)
can you switch the civic ex with the integra lca's. because i had the same problem i took my friends rear sway bar also b/c he is selling the car. can i put my ex lca's on his integra and put his on mine with no prob?
Re: (CRITTERMATT)
ok so is there a away for me to get a 94 integra rear sway bar onto my car. i have a 99 civic ex. oh and what is the difference between the civic and integra LCA's?
thanks
thanks
Re: (GreenEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenEX »</TD></TR><TR><TD CLASS="quote">ok so is there a away for me to get a 94 integra rear sway bar onto my car. i have a 99 civic ex. oh and what is the difference between the civic and integra LCA's?
thanks</TD></TR></TABLE>
i believe the 92-95 civic lca's are the same length as integra but the 96-00 civic lca's are longer and will not work. As for the rear subframe, you can only use one of the mounting holes and you will have to drill a hole for the second one.
ThefirstPACT
22
02-08-2005 11:42 AM
