Shaving heads?
Old Jan 10, 2002 | 11:48 AM
Speed_Ricer99's Avatar
Default Shaving heads?
Would shaving .030 off of the bottom of my 1.6 SOHC VTEC head and therefore lowering my compression give me decent power? Somone I consider reputable told me it would help. Of course i know I'd have to use a higher octane fuel... but would it work? What gains could I expect?
Old Jan 10, 2002 | 11:57 AM
J T*'s Avatar
Default Re: Shaving heads? (Speed_Ricer99)
I had a D16Y8 with a Gude Racing cam in it. with headers , intake and exhaust it ran a 15.5. I eventually bent some valves and burnt or ground down the cam bearing so I purchased a new stock D16Y8 head. I milled it .40 and just like that with the same headers intake and exhaust setup I ran 15.7's and 15.8's.
Almost as fast as with a $400 cam.
never had any problems with it afterwards, so I'd say its a great cheap investment if done right, unless you plan on going turbo.
hope that helps out.
[Modified by 50percentRice, 8:57 PM 1/10/2002]
[Modified by 50percentRice, 8:58 PM 1/10/2002]
Old Jan 10, 2002 | 11:58 AM
hybridkid's Avatar
if you mill your head you'll be raising your compression, not lowering it. dont bend valves
Old Jan 10, 2002 | 01:12 PM
agent marlon's Avatar
Default Re: Shaving heads? (hybridkid)
hydrid kid is right...it will raise your compression not lower it...
i milled my head 45 thousandths..plus i/h/e and ran 15.5
Old Jan 10, 2002 | 01:16 PM
J T*'s Avatar
I bent valves while road racing, downshifted from 5th to 2nd ( by mistake) not because my head was milled.
Old Jan 10, 2002 | 03:14 PM
Default Re: Shaving heads? (50percentRice)
ouch!...did your car sound like a lawnmower on steriods?....how many valves did you bend?
[Modified by 95 EJ, 12:27 AM 1/11/2002]
Old Jan 10, 2002 | 03:49 PM
EG8R's Avatar
Default Re: Shaving heads? (95 EJ)
I've never bent valves and my timing belt slipped twice.... Gald it's not a Honda. Thats prolly the only good thing about my car though.
Old Jan 10, 2002 | 04:22 PM
J T*'s Avatar
yeah kinda sounded like a couple of people were pounding the engine with hammers under my hood
brenen8
Feb 11, 2011 01:44 AM
titi_vtec
Jul 6, 2010 03:42 PM
Low3Piru
Jan 31, 2008 12:51 PM
89SiRef
Dec 11, 2007 06:17 AM
honda94civicturbo
10
Nov 24, 2004 08:25 PM
