exhaust piping system question
Old Jan 13, 2005 | 06:02 PM
mkiv98's Avatar
Default exhaust piping system question
Is it restrictive if the exhaust system starts out smaller and then gets bigger?
say right now if my header collector is a 2.0" into a 2.0" cat and then to a bigger catback (say like 2.38" or so, or ITR size) then is that still efficient? or does the piping difference cause a problem in terms of flow?
Old Jan 13, 2005 | 07:16 PM
DarkDragon's Avatar
Default Re: exhaust piping system question (mkiv98)
depends on how much exhaust is trying to flow at that point. The more gas thats flowing the more restrictive it is on a small pipe but it is opposite with bigger pipe such as if too little gas is flowing thru a big pipe it slows and increases back pressure. The smaller pipe pretty much acts like a venture speedign up the gases and keeping them hot and when it hits the larger piping it has a good amount of velocity and can almost cause a vacume. This is why piping size is so important to exhaust gas output
Old Jan 13, 2005 | 07:33 PM
xprohx's Avatar
I think too much
Default Re: exhaust piping system question (DarkDragon)
It is better to start small to big, rather than big to small - simply put.
Old Jan 13, 2005 | 07:36 PM
DarkDragon's Avatar
Default Re: exhaust piping system question (xprohx)
ya thats pretty much it
Old Jan 13, 2005 | 10:19 PM
mkiv98's Avatar
so...a 2.0" collector to a 2.5" or stock cat to a bigger catback would work well?
Old Jan 14, 2005 | 01:05 AM
teknoracing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xprohx &raquo;</TD></TR><TR><TD CLASS="quote">It is better to start small to big, rather than big to small - simply put.</TD></TR></TABLE>
Not necessarily, im gonna run a 3" downpipe to a 2.5" catback exhaust on my GTI and its been proven to get better results then 2.5" turbo back.
Old Jan 14, 2005 | 01:23 PM
yee SERIOUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkiv98 &raquo;</TD></TR><TR><TD CLASS="quote">so...a 2.0" collector to a 2.5" or stock cat to a bigger catback would work well?</TD></TR></TABLE>
that'll be fine i think i'm going to do the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teknoracing &raquo;</TD></TR><TR><TD CLASS="quote">
Not necessarily, im gonna run a 3" downpipe to a 2.5" catback exhaust on my GTI and its been proven to get better results then 2.5" turbo back. </TD></TR></TABLE>
never heard of that....
Old Jan 14, 2005 | 02:24 PM
Default Re: exhaust piping system question (LiTtOGPiMp)
Well theres dyno sheets on some of the VW forums and i dont want to hijack this thread but i am giving my opinion based on dynosheets and butt dynos. So to each his own.
I have noticed gains with catback systems and stock manifold, but the addition of an aftermarket header will increase power output
Old Jan 14, 2005 | 03:41 PM
mkiv98's Avatar
Default Re: exhaust piping system question (teknoracing)
well if i had a turbo id just get an electric cutout.
Employee24
10
Apr 10, 2008 04:52 AM
9civic8
Welding / Fabrication
18
Oct 19, 2005 03:24 PM
PreludePhill
Feb 2, 2005 06:27 PM
