oil presser sensor keep car from fireing?
i have a d15b japan motor and i have done everything to do with the fireing(got all the new parts)but im still not getting fire. HELP
OIl pressure sensor can't sense oil pressure if the engine is not running!
If you still can't get the engine to fire, Are you getting sparK?
If not, is voltage coming out the dizzy?
If not, is voltage reaching the dizzy?
fs
fs
my freind is a macanice and he told me that the oil presser sensor if its not telling the ECU that its there and working that it wont fire becuase its a safty thang so u dont blow your motor but im not sure about that thats why im asking on here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicdxracer »</TD></TR><TR><TD CLASS="quote">my freind is a macanice and he told me that the oil presser sensor if its not telling the ECU that its there and working that it wont fire becuase its a safty thang so u dont blow your motor but im not sure about that thats why im asking on here</TD></TR></TABLE>
Your friend is wrong.
On certain makes, the oil pressure switch is bypassed when you turn the ignition switch, then when the engine starts, it will complete the circuit. If no, or too little oil pressure is detected, then the fuel pump is cut and the engine shuts down.
Although i was never an FI specialist, i do not believe Honda ignition circuits are configured this way.
fs
fs
ya thats the way my buddy told me but i waznt sure i tought i would ask on here an if u find out anything plz. let me know thank
oh my bad
so what ur saying is that if the oil presser sensor is bad that it would still start but it would shut off after that if thats what ur saying then its back to where I started
on my 1996 Civic EX D16Y8, i disconnected the oil pressure sensor (yes the stock oil electrical pressure sensor) and hooked up a steel braided line to the hole to use for my mechanical gauge.
I have lost the low oil dummy light, but my car drives fine and no check engine light. and i've been doing this for months. i wonder if the oil pressure sensor is directly connected to ECU. if it does, why don't I get a check engine light or why doesn't my car go into limp mode?
linkinparkfallower
Sep 3, 2006 09:20 AM
