How to Remove the "H" logo in the hood?
Howdy...Do you guys know how to best remove the "H" logo on the hood? I just want to make sure I'm doing it right.
And what did you do to cover the 2 holes? did you repaint the whole hood?
Tnx
Tnx
credit card. most people don't remove it b/c it leaves two holes. the only way to get "rid" of them is to shave them (bring car to body shop, weld holes closed, repaint)
k...i'll try it. it looks very good without the H though.
i'm thinking some bondo and some touch up paint will do? maybe the results will be not good
it does look clean without the emblems, but yea like the post above, it leaves two holes. your eg also looks very clean with the emblem on too...its your choice tho. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Edge.ONE »</TD></TR><TR><TD CLASS="quote">dental floss
yea, dental floss is easiest in my opinion. also, get some goo gone from pep boys and clean the adhesive it leaves behind.
</TD></TR></TABLE>yea, dental floss is easiest in my opinion. also, get some goo gone from pep boys and clean the adhesive it leaves behind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WongFeihung »</TD></TR><TR><TD CLASS="quote">
yea, dental floss is easiest in my opinion. also, get some goo gone from pep boys and clean the adhesive it leaves behind. </TD></TR></TABLE>
The front emblem on the hood is NOT glued on. It is riveted on. When you pop it off, it leaves 2 holes behind. Those holes either need to be bondoed in or welded in and repainted.
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WongFeihung »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apm »</TD></TR><TR><TD CLASS="quote">k...i'll try it. it looks very good without the H though.
i'm thinking some bondo and some touch up paint will do? maybe the results will be not good</TD></TR></TABLE>
you won't be able to get a good look with bondo and touch up paint , I work in a body shop trust me.
so the body shop needs to repaint the whole hood i supposed?
i was hoping there's a quickie way of doing it. and also the backside of the holes are blocked. pretty tought to put bondie
quickie ways always turn out shitty, if you want yoiur car looking clean do it right the first time. and if your not familiar on how to do it, maybe you shouldnt do it at all your first time and have someone else who knows how to do a clean job help you so your not dissapointed with the results
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">I have a question. Do the OEM replacement or Certifit peices have the holes there for the emblems?</TD></TR></TABLE>
i hear that oem has dimples where the H should and certifit parts have the holes. not 100% sure tho.
drumminforev
Welding / Fabrication
21
Nov 12, 2006 07:10 PM
drumminforev
12
Nov 11, 2006 09:52 PM
