Help me locate a part
Old Jan 13, 2005 | 06:24 AM
Boostage's Avatar
Default Help me locate a part
I dropped in a 99 b16 in my 94 ex and it has a JG edlebrock intake with stock throttle body, well the stock sohc throttle linkage doesnt reach..
so I am trying to locate the dohc del sol linkage but I cant tell if it number 9 or number 11 that I need (those are the only ones that you can click on)
which one do I need?
Old Jan 13, 2005 | 06:33 AM
_BEN_'s Avatar
Default Re: Help me locate a part (Boostage)
Just out of curiosity. Would the cable reach if the bracket was put on backwards?
If not you could fabricate an extension for cheap and quite easily.
Old Jan 13, 2005 | 07:09 AM
Orangecivic251's Avatar
Default Re: Help me locate a part (_BEN_)
hmm that doesn't seem right i used my s0hc cable on my 00 swap. but eother way i belive it would be 9 ur looking for good luck lemme knwo how it goes
Old Jan 13, 2005 | 07:16 AM
hype r 555's Avatar
Default Re: Help me locate a part (OrangeCiviC251)
it is #9 if that is the only one that you can axess , however when looking at the picture and from my exp. it actaully is #10 because if yu look and the #10 throttle cable it feeds into the throttle cable braket -#16 which is the piece that bolts onto the manifold itself
Old Jan 13, 2005 | 08:34 AM
Default Re: Help me locate a part (lsed-eg)
c i know where you coming form but the start of the cable starts from the brake pedal corrct me if i'm reading the diagram wrong i completely understand what your saying but both could feed to the manifold bracket by the picture. lol i dunno
Old Jan 13, 2005 | 09:09 AM
dantastic's Avatar
if you wanna do it the "right way" don't bother with fabbing brackets up. you can use an b16, b18b, or it-r throttle cable...
devney
Aug 3, 2007 08:39 PM
chue_li
Apr 18, 2006 06:18 AM
JDMCivicEF9
May 6, 2005 12:33 PM
Boostage
Jan 15, 2005 07:45 AM
dynamo
Sep 20, 2002 11:34 AM
