Help me ID this injector
Old Jan 13, 2005 | 04:13 AM
DanishR's Avatar
Default Help me ID this injector
I bought these injectors from a member and was told they are RC750cc and would fit a 1998 Integra Type-R. They don't fit because of that little piece of plastic circled in the pictures.
Anyone know what injectors they are?
It says PKCX-750 on them.
Old Jan 13, 2005 | 04:28 AM
THEUSED's Avatar
Dont mean to be a dick but did you put them in upside down, that little plastic piece is the clip that the harnesses hook into
Old Jan 13, 2005 | 05:21 AM
DanishR's Avatar
Default Re: (THEUSED)
The connection on the harness does not have room for that little piece of plastic. It is a European ITR if that matters? The stock injector does not have that little plastic thing.
Old Jan 15, 2005 | 06:41 AM
DanishR's Avatar
Default Re: (DanishR)
I am told they are injectors for a Prelude. I thought they would fit an ITR as well. Shouldn't Prelude injectors fit? I guess not.
Old Jan 15, 2005 | 08:34 AM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED &raquo;</TD></TR><TR><TD CLASS="quote">Dont mean to be a dick but did you put them in upside down, that little plastic piece is the clip that the harnesses hook into</TD></TR></TABLE>
Don't mean to be a dick, but did you look at his pictures?
Those look to be Precision injectors. They are not RC, but they are the same ones RC uses. RC removes that little tab, but it kooks to me like you will still need to wire OBD-1 '92-'95 injector connectors into your harness. What are you using to calibrate the fuel maps for the 750cc injectors?
Old Jan 15, 2005 | 10:28 AM
DanishR's Avatar
Default Re: (Jim Truett)
Thanks.
They are RC injectors, though. It says RC on them.
I don't really want to modify the harness. I'll just sell them and buy injectors that fit right in. Unless I can just cut away that plastic piece, but that is probably not a good idea, they put it there for a reason, I think
I am using Überdata to tune it.
Old Jan 15, 2005 | 06:20 PM
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">
Those look to be Precision injectors. They are not RC, but they are the same ones RC uses. RC removes that little tab, but it kooks to me like you will still need to wire OBD-1 '92-'95 injector connectors into your harness. What are you using to calibrate the fuel maps for the 750cc injectors?</TD></TR></TABLE>
those are not precision injectors and that little tab can be removed with a xacto knife and you will be fine nothing will harmed just make sure if they are a peak and hold injector you use a resistor box on them.
Hawks-At-Angels-12
Jul 7, 2006 02:07 PM
BOOSTED_JDM_DB8
May 15, 2006 07:07 PM
b17integra
Jun 19, 2005 05:40 PM
careawholelot
Sep 23, 2004 11:06 AM
power_fc
Jul 30, 2001 06:51 AM
