CTR cams installation
Old Jan 12, 2005 | 09:57 PM
caranjo's Avatar
Default CTR cams installation
I have a few newebie questions on cam installation. I have CTR cams and want to install them in my B16A2 engine. I know i shouldn't skimp on things but i really am trying to keep my costs low where it is safe to do so,
1) Do i need a new head gasket / full gasket fit?
2) Do i need a new timing belt?
3) How many hours labour will it take to do if done by a professional?
4) Can i run my stock B16A2 cam gears and gain the full benefit of the cams? Or do i really require full aftermarket adjustable cams?
thanks
Old Jan 12, 2005 | 10:10 PM
PrettyLude's Avatar
you won't need the whole gasket set, change the headgasket if you need to, don't fix it if it ain't broken
2. how long has it been since you changed it last time, it would be convenient to since its all gonna come off.
3. about 2 hours
4. i would definately get some cam gears, btw i have toda's and strs on both my vehicles
Old Jan 13, 2005 | 02:04 AM
caranjo's Avatar
Default Re: (PrettyLude)
yeah, i had the belt replaced by Honda at 60,000 miles and my car has now done about 83,000.
so hopefully i can get away from fitting just the cams and and gears? And i guess if the tension in the valve sproinsg are ok too, no need changing them too!
Also, does it really matter if it is a named brand for the cam gears?
Old Jan 13, 2005 | 07:03 AM
PrettyLude's Avatar
it doesn't have to be name brand, just that the teeth is correct, and the timing marks are correct
Old Jan 13, 2005 | 08:21 AM
JSPECEX's Avatar
i was under the impression that you are suposed to run the springs and retainers from the ctr. i think you can get away with it but don't take it past 8200
Old Jan 13, 2005 | 08:53 AM
rough_draft's Avatar
why do you need to take the head off?
Old Jan 13, 2005 | 10:14 AM
ef8 h0!'s Avatar
Default Re: (omghi2ubbq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omghi2ubbq &raquo;</TD></TR><TR><TD CLASS="quote">why do you need to take the head off?</TD></TR></TABLE>
you dont need to unless you plan on doing valves or valve springs, once you get down to the cams you may as well take the head off, its 8 bolts after that, plus you should do a new head gasket for the hell of it, it will be worth it while your there. fel pro head sets for a 99 si are like 125-150 i think and you get every gasket from the head gasket up. It would so be worth it to take your time and spend a couple extra dollars (pounds). make sure you send your head out to have it resurfaced also.
labor will be about 2-3 hours depending on the shop and or tech that does it. you should also do a t-belt water pump and belt tensoner while your there (verry easy with the head off.) and get some skunk 2 cam gears!
Good luck!
Old Jan 14, 2005 | 12:37 PM
clayne's Avatar
Default Re: (bernie'sb16crx)
Removing the head isn't just as simple as "8 bolts." Remember all of the crap connected to it.
Intake manifold, exhaust manifold, vacuum lines, water lines, fuel lines to the IM, etc.
Easily twice the work.
Old Jan 14, 2005 | 02:27 PM
lol no i know how to remove the head, i'm asking him why does he need to remove the head to install cams? its pointless
t-powersi
Sep 10, 2007 08:52 PM
1JDMDOMINICAN
10
Oct 7, 2005 04:32 AM
Rocket
Apr 8, 2005 01:44 PM
StinkyTofu
Jan 4, 2002 09:35 AM
VTECAcuraGSR
Jun 17, 2001 06:18 PM
