how much fluid?
Old Jan 12, 2005 | 06:40 PM
1998CivicLX's Avatar
Default how much fluid?
I have a 98 civic 5 speed and dont know how much fluid to put. Any input is great. Thanks!
Old Jan 12, 2005 | 06:42 PM
civictildeath's Avatar
Default Re: how much fluid? (1998CivicLX)
well you 17 gallons of it.
what type of fluid??
Old Jan 12, 2005 | 06:43 PM
Tranny
Old Jan 12, 2005 | 06:45 PM
Default Re: (1998CivicLX)
my chiltons manual says 3.8 pts
Old Jan 12, 2005 | 06:46 PM
Thanks!
Old Jan 12, 2005 | 06:47 PM
civiccpedx's Avatar
just wait till it pours out the filler whole.
Old Jan 12, 2005 | 06:48 PM
Default Re: (civiccpedx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx &raquo;</TD></TR><TR><TD CLASS="quote">just wait till it pours out the filler whole. </TD></TR></TABLE>
ya set up a funnel and start pouring and take a nap while it fills j/k
Old Jan 12, 2005 | 07:11 PM
beerbongskickass's Avatar
Default Re: (civictildeath)
I have the same tranny... it's like a little less than 2 quarts. Just pour it in until it starts coming out the drain plug like these other guys said. I pour mine in through the reverse light sensor hole... it's pretty easy that way.
Old Jan 12, 2005 | 07:29 PM
well i changed my tranny fluid now. actually the nut for the filler hole was rounding off and it was hard to take off the bolt so I just filled it through the drain hole.
Old Jan 12, 2005 | 07:32 PM
00Red_SiR's Avatar
All Motor Mentor
if you did you won't have enough fluid in there since it should be filled to the point where it comes out the upper fill bolt hole.
Old Jan 12, 2005 | 07:35 PM
ABK's Avatar
ABK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1998CivicLX &raquo;</TD></TR><TR><TD CLASS="quote">well i changed my tranny fluid now. actually the nut for the filler hole was rounding off and it was hard to take off the bolt so I just filled it through the drain hole.</TD></TR></TABLE>
yeah your tranny is going to blow up
Old Jan 12, 2005 | 07:44 PM
Lol... that's like putting oil in your car through the oil drain plug, just think about it for a second.
b e e's Avatar
yup. mine car took a little less than 2 quarts
Old Jan 12, 2005 | 08:00 PM
how should it feel like with the new fluid? i mean it shifts more smoothly now.
Old Jan 12, 2005 | 08:02 PM
ABK's Avatar
ABK
if you didn't know you can run a manual trans without any fluid but then it will seize up. If you wonna keep your tranny fill it up the right way. If you can't do it pay some one to do it, or take it to the shop.
Old Jan 12, 2005 | 08:24 PM
b e e's Avatar
shifting should be more smoothly. correct.
ABlais
Jun 18, 2008 06:52 AM
x_tuh_sy
Dec 10, 2007 03:35 PM
dumped_ej1
14
Oct 25, 2005 01:21 PM
UmaMamoo
Mar 30, 2004 11:45 AM
ooooitswilson
18
Sep 15, 2003 02:09 PM
