running a b18c1 with an unchipped p28
Old Jan 12, 2005 | 06:20 PM
lazynok's Avatar
Default running a b18c1 with an unchipped p28
well I have a 98 b18c1 and so the ecu will not work and i am basically out of money.
can i just plug the engine in, and use my p28? ..for the time being until i can find a obd1 p72 so i can BAR it.
it will run, right? i guess i wont add the knock/iab wires because i just want toget my car running again. the engine won't run if "safe mode" or whatever, right?
just temporary..
thanks
Old Jan 12, 2005 | 10:22 PM
lazynok's Avatar
Default Re: running a b18c1 with an unchipped p28 (lazynok)
up cause i can't afford a real ecu =[
Old Jan 12, 2005 | 10:23 PM
triple_s1x's Avatar
yes it will run, will throw a couple cels though.
Old Jan 13, 2005 | 12:04 AM
lazynok's Avatar
Default Re: running a b18c1 with an unchipped p28 (triple_s1x)
why would it throw any cels?
i would think because its a p28.. it wouldnt care about the iabs and knock sensor.. so what other cels could it possibly throw?
Old Jan 13, 2005 | 12:40 AM
EKtypeRhaTcH's Avatar
i had the same problem too but i just got it chipped, just get your p28 chipped. you will be able to run it on the unchipped one but you cant really get on the gas and it runs lean i think. plus i read something about retarding the timing. not really shure though.
Old Jan 13, 2005 | 12:46 AM
Mike Ockhurts's Avatar
Default Re: (EKtypeRhaTcH)
stock p28 will NOT give u ANY codes, i know from experiance. the only thing that it WILL do, is cause your motor to run a lean because of the lack of fuel, because it is from a single cam motor
Old Jan 13, 2005 | 12:59 AM
lazynok's Avatar
Default Re: (cx Son)
okay thanks. as long as it gets me around town until i can get a obd1 p72 i'll be haoppy =]
thanks everyone
Old Jan 13, 2005 | 01:56 AM
lazynok's Avatar
Default Re: (lazynok)
can i wire up the IAB to vtec solinoid so the secondaries open with vtec?
Old Jan 13, 2005 | 11:20 AM
lazynok's Avatar
anybody???? iab to vtec??
Old Jan 13, 2005 | 11:28 AM
kun3racer's Avatar
bump....id like to know also, it sounds like a good idea. run a p28 without having to change the manifold.
Old Jan 13, 2005 | 11:42 AM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazynok &raquo;</TD></TR><TR><TD CLASS="quote">can i wire up the IAB to vtec solinoid so the secondaries open with vtec?</TD></TR></TABLE>
Im pretty sure it wont matter what you do because the ECU is not set up to run secondaries.
Old Jan 13, 2005 | 11:44 AM
kun3racer's Avatar
Default Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">
Im pretty sure it wont matter what you do because the ECU is not set up to run secondaries.</TD></TR></TABLE>
do you understand the question?
Old Jan 13, 2005 | 01:49 PM
lazynok's Avatar
Default Re: (kun3racer)
after all... i'm guessing it just sends out a voltage to the IAB solinoid.... which is most likely the same voltage as for vtec... so it should work both ways?
ehh maybe i can just wire it up to a button and right BOOST next to it and put it on my steeringwheel....
Old Jan 13, 2005 | 03:24 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazynok &raquo;</TD></TR><TR><TD CLASS="quote">after all... i'm guessing it just sends out a voltage to the IAB solinoid.... which is most likely the same voltage as for vtec... so it should work both ways?
I doubt it is the same voltage as the solenoid, and VTEC engages at a different RPM than the IAB. Which in turn will probably not help you with power at all.
You are better off just running the p28 without a knock sensor and dont worry about the secondaries.
Old Jan 13, 2005 | 03:42 PM
JDMH22HATCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cx Son &raquo;</TD></TR><TR><TD CLASS="quote">stock p28 will NOT give u ANY codes, i know from experiance. the only thing that it WILL do, is cause your motor to run a lean because of the lack of fuel, because it is from a single cam motor</TD></TR></TABLE>
You are better off just running the p28 without a knock sensor and dont worry about the secondaries.</TD></TR></TABLE>
Just get the p28 chipped or drive it easy until you can afford to chip it. The p28 imo is a better ecu than the p72.
Old Jan 13, 2005 | 03:43 PM
NeverEverSatisfied's Avatar
People on E-bay Chip for Cheap.
Old Jan 13, 2005 | 05:43 PM
kun3racer's Avatar
you do know that the secondaries are open until you start the car right?
SMOOTHN
Engine Management and Tuning
Jul 6, 2010 02:28 PM
PostSRT
Jan 16, 2008 07:26 PM
MOVE OVER
Sep 6, 2007 08:59 AM
.I.Need.Money.
Aug 4, 2006 12:42 AM
IdotheSHOCKER
May 30, 2002 09:42 AM
