obd1 ecu.. switch from auto to manual
Old Jan 12, 2005 | 04:59 PM
skaterdx's Avatar
Default obd1 ecu.. switch from auto to manual
i need to convert my p28 from auto to manual.. i pulled up some directions from pgmfi.org and they say to remove 2 resistors and replace one with a jumper wire.. but, ive heard that your supposed to remove a high side switch also or instead of? i just dont want to remove these 2 resistors and find out it didnt work, then have to solder them back in..
thanks
Old Jan 12, 2005 | 05:30 PM
2lua's Avatar
Default Re: obd1 ecu.. switch from auto to manual (skaterdx)
you went to the right place, but need to spend a bit more time tho. their info are very good.
Old Jan 12, 2005 | 06:20 PM
Jim Truett's Avatar
Just remove the resistors and install the jumper. You do not need to remove the high side switches, unless you want them to convert another ECU to VTEC.
mmag2982
Engine Management and Tuning
Jun 5, 2016 09:50 AM
wishingiam
Jul 17, 2011 10:39 PM
RamenDA9noodles
Sep 24, 2007 07:30 AM
THC07
Jan 9, 2006 04:05 PM
mrnice1058
Jan 11, 2005 07:19 PM
