ECU pins
Old Jan 12, 2005 | 04:15 PM
99hatch's Avatar
Default ECU pins
How do i get them out of the harness? i do not know how to remove the white plastic thing on top of the harness. Please help me out!
Old Jan 12, 2005 | 04:19 PM
99hatch's Avatar
Default Re: ECU pins (99hatch)
bump i am trying to do this now, any help is appreciated!!!
Old Jan 12, 2005 | 04:57 PM
99hatch's Avatar
ok i am able to get the white piece to move up a little bit, and i can almost get the pin in all the way but it seems stuck on something. anyone know how to do this correctly?
Old Jan 12, 2005 | 05:09 PM
99hatch's Avatar
i know someone out there has to know how to do this!! stop flaming some noob for 5 seconds and help me out!!!!
Old Jan 12, 2005 | 05:19 PM
99hatch's Avatar
bump
Old Jan 12, 2005 | 05:28 PM
99hatch's Avatar
and another
Old Jan 12, 2005 | 05:34 PM
99hatch's Avatar
ttt
Old Jan 12, 2005 | 05:44 PM
2lua's Avatar
use a paper clip or a small screwdriver. there is a plastic tab holding the pin in place. obd1 harness you push and lift the tools from the front of the plug, and pull from the wire from the back, pushremember to do it slow. obd2 harness you have to lift the white lock in the middle of the plug and then push and lift the tool from the front of the plug and pull the wire from the back.
Old Jan 12, 2005 | 05:47 PM
99hatch's Avatar
Default Re: ECU pins (2lua)
so to insert the plug on obd2 i would have to lift the white thing and then push down on the pin from the front?
Old Jan 12, 2005 | 05:54 PM
2lua's Avatar
yeah! cause the white clip lock all the pins, but you still have to push and lift the plastic clip inside the plug and pull the wire at the same time, but make sure the white clip is pull up.
Old Jan 12, 2005 | 06:19 PM
Turbogixxer's Avatar
OBD1:
http://www.ff-squad.com/tech/w...l.jpg
OBD2:
bpr00civicsi
Jun 18, 2018 06:23 PM
zach1288
11
Feb 6, 2009 09:25 AM
ozrednsx
12
Oct 22, 2007 12:14 AM
quiksheit
Apr 14, 2004 03:54 PM
Se-rv-Tak
Aug 24, 2003 07:03 PM
