Boost Creep...what is it and what can I do to prevent it???
Old Jan 12, 2005 | 02:56 PM
1JDMDOMINICAN's Avatar
Default Boost Creep...what is it and what can I do to prevent it???
Ok, i'm going to boost my GSR soon and while asking questions on what turbo manifold to buy, someone mentioned boost creep. They didn't explain very well, so I don't know much about it. i would like to know what it is before i boost my motor and blow it. I mentioned that I wanted to get either the Rev Hard or the DRAG cast iron manifolds cuz they are within my budget and they let me keep AC/Power Steering....besides, most heads on here use them and it seems like they are very durable manifolds....no cracking, etc.
Just one thing got mentioned and it was the fact the boost creep happens with these manifolds because of the place where the wastegate is mounted at. The guy said that since the wastegate only bleeds excess boost or exhaust gas from one cylinder, then it experiences boost creep. He said its better to get a manifold with the wastegate place in the center of the manifold where it bleeds off all four cylinders....is this true?
I see on HT and in most magazines that people have manifolds that the wastegate goes placed on just one of the tubes or cylinders or on some pipe coming off the manifold.....is this guy correct or is he just talkin trash???
Can someone explain boost creep to me also??
Old Jan 12, 2005 | 03:16 PM
primeredbeast's Avatar
Default Re: Boost Creep...what is it and what can I do to prevent it??? (mugenda6)
go with rev-hard and a tial wategate and you'll be set just my opinion
Old Jan 12, 2005 | 03:35 PM
DefiantGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenda6 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, i'm going to boost my GSR soon and while asking questions on what turbo manifold to buy, someone mentioned boost creep. They didn't explain very well, so I don't know much about it. i would like to know what it is before i boost my motor and blow it. I mentioned that I wanted to get either the Rev Hard or the DRAG cast iron manifolds cuz they are within my budget and they let me keep AC/Power Steering....besides, most heads on here use them and it seems like they are very durable manifolds....no cracking, etc.
Can someone explain boost creep to me also?? </TD></TR></TABLE>
Drag is notorious for boost creep b/c it bleeds off of one cylinder.
In general, what he said is correct.
Old Jan 12, 2005 | 05:11 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenda6 &raquo;</TD></TR><TR><TD CLASS="quote">Can someone explain boost creep to me also?? </TD></TR></TABLE>
Boost creep is a result of having to small a wastegate. To prevent boost creep, you have to get a larger WG or if you have an internal WG enlarge the WG orifice somehow.
Think of it this way: exhaust gasses leaving the engine have 2 ways to get to the tailpipe, either through the wastegate or through the turbine. if the wastegate orifice is too small, it wont let out the exhaust gasses fast enough. So instead of exiting out the wastegate, the exhaust gasses will leave through the turbine.
And if you remember back to Turbo 101, the wastegate controls boost by allowing exhaust gasses though so that it wont go through the turbine. Since your small WG is unable to divert enough gas away from the turbine to keep boost down, you get boost creep because the gasses have to exit through the turbine instead, increasing turbine speed which increases compressor speed which equals higher boost.
Old Jan 13, 2005 | 10:12 AM
Default Re: Boost Creep...what is it and what can I do to prevent it??? (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">
And if you remember back to Turbo 101, the wastegate controls boost by allowing exhaust gasses though so that it wont go through the turbine. Since your small WG is unable to divert enough gas away from the turbine to keep boost down, you get boost creep because the gasses have to exit through the turbine instead, increasing turbine speed which increases compressor speed which equals higher boost.</TD></TR></TABLE>
so wat size of wastegate would u recommend? a 35mm or a 40mm wastegate? I'm planning to reach at least 300-350whp.
Old Jan 13, 2005 | 10:13 AM
wat manifold also would u recommend?
Old Jan 13, 2005 | 10:16 AM
btotherizzle's Avatar
Default Re: Boost Creep...what is it and what can I do to prevent it??? (primeredbeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primeredbeast &raquo;</TD></TR><TR><TD CLASS="quote">go with rev-hard and a tial wategate and you'll be set just my opinion</TD></TR></TABLE>
this will be cheap and effective, or go with a turbosmart wastegate, they're a better deal in my opinion because you get 4 springs and the welding flanges.
Old Jan 13, 2005 | 01:43 PM
DC2 BOOST's Avatar
Go wid SFP street turbo manifold thier wastegate elbow flange is in the middle of the manifold u could either choose a tial 38mm or 40mm flange
Old Jan 13, 2005 | 05:43 PM
Default Re: Boost Creep...what is it and what can I do to prevent it??? (DC2 BOOST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 BOOST &raquo;</TD></TR><TR><TD CLASS="quote">Go wid SFP street turbo manifold thier wastegate elbow flange is in the middle of the manifold u could either choose a tial 38mm or 40mm flange </TD></TR></TABLE>
Ok, but will the SFP manifold let me keep my AC and Power steering? That's why I wanted to know which manifold between the Rev Hard or DRAG to use because I know those two let you run AC and PS.
Old Jan 13, 2005 | 11:10 PM
PrettyLude's Avatar
they have both ac & ps compatible and not
Old Jan 18, 2005 | 12:48 PM
anyone know where I can get the SFP manifold?
Old Jan 18, 2005 | 02:20 PM
Default Re: (mugenda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenda6 &raquo;</TD></TR><TR><TD CLASS="quote">anyone know where I can get the SFP manifold?</TD></TR></TABLE>
from their web site, if you want the address, you must jump up and down 3 times
Old Jan 18, 2005 | 04:52 PM
integ22's Avatar
SFP are good manifolds, but too pricey for my budget. It sounds like you should look at the Blox manifolds because they are basically copies of the revhard manifold. Check it out...https://honda-tech.com/zerothread?id=1115004
Old Jan 20, 2005 | 09:32 AM
Default Re: (integ22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integ22 &raquo;</TD></TR><TR><TD CLASS="quote">SFP are good manifolds, but too pricey for my budget. It sounds like you should look at the Blox manifolds because they are basically copies of the revhard manifold. Check it out...https://honda-tech.com/zerothread?id=1115004</TD></TR></TABLE>
Anyone on here ever use the Blox manifold? how reliable are they? Have they cracked on any of yall and do they experience boost creep?
Synapse
May 1, 2007 08:42 AM
faSHOwidIT
Jan 31, 2007 03:59 PM
RedTegLS
Feb 4, 2004 04:22 AM
fiftee_su
Jul 11, 2003 08:15 AM
