quick questions about tranny fluid on a em1 how many quart?
Old Jan 12, 2005 | 02:10 PM
jeffchaisi's Avatar
Default quick questions about tranny fluid on a em1 how many quart?
i haven't done a tranny fluid change for a while any way i just changed my tranny fluid on my 99 si and i put in 3.2 quart i just want to make sure that's right. let me know guys. thanks
Old Jan 12, 2005 | 06:12 PM
jeffchaisi's Avatar
TTT
Old Jan 12, 2005 | 06:18 PM
civictildeath's Avatar
Default Re: (jeffchaisi)
3.8 pts
Old Jan 12, 2005 | 06:20 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: quick questions about tranny fluid on a em1 how many quart? (jeffchaisi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffchaisi &raquo;</TD></TR><TR><TD CLASS="quote"> i just changed my tranny fluid on my 99 si and i put in 3.2 quart</TD></TR></TABLE>
all depends on how much you got out of it when you drained it. was it on a level surface? did you remove the filler bolt, and pour the new fluid in until you saw it trickle out? 3.2 seems a bit high, usually it is about 2 1/2~3/4 or so for a drain/refill.
Old Jan 12, 2005 | 06:50 PM
DarkCyde SI's Avatar
yeah 3.2 is too high. i just changed mine the other weekend. it should be about what the other guy said which is 2 1/2. if you filled it through the fill bolt it shouldn't be able to take more than its supposed to because when it reaches it's required level the oil should just start spilling out of the filler hole. but i remember reading something on here where the guy fills it through like the speed sensor or something like that then if you did it that way then you would be able to overfill your tranny
Old Jan 13, 2005 | 02:27 AM
jeffchaisi's Avatar
damn i guess i have to take alittle out of it. yeah i fill it from the vss sensor.
aries331
Dec 1, 2007 01:13 PM
.one lane
May 2, 2006 05:38 AM
raylude
Sep 14, 2005 05:33 AM
AlekSir
Mar 22, 2005 07:20 AM
dork
Jul 9, 2004 09:27 AM
