engine light code 41 - 02 sensor
Old Jan 9, 2002 | 11:59 PM
DreamSpeed's Avatar
Default engine light code 41 - 02 sensor
41 Primary Heated O2 Sensor Heater Open or short in Primary O2 sensor heater circuit
my ecu is throwing code 41 how do i fix it? i already changed the o2 sensor but it's still on and im running rich. i might have wired it wrong, the o2 sensor wires go directly to the ecu right? anyone have a wiring diagram for this? my car is a 92 hatch obd1
Old Jan 11, 2002 | 11:47 AM
hondachick81's Avatar
Default Re: engine light code 41 - 02 sensor (DreamSpeed)
dumb question, but did you reset your ecu?
Old Jan 11, 2002 | 11:53 AM
Jackson's Avatar
is your o2 one wire or 4 wire? some of the canadian version civics came with one wire o2 sensors.
Old Jan 13, 2002 | 09:44 PM
nwarp's Avatar
Default Re: engine light code 41 - 02 sensor (Jackson)
how do i reset my ecu (94 gsr) ???
Old Jan 13, 2002 | 11:29 PM
TurboBumblBee's Avatar
i got the same code being put out from my ECU.. i had a friend replace my clutch when it went out they disconnected the o2 sensor and also reverse sensor on the tranny.. i get the car back and the check engine light was on.. i have not replaced the o2 sensor but i probably wont now that you have done it and it still has not fixed the problem. i have not fixed it yet but i think that all i will have to do is splice the wires together and make sure the electrical connector isnt fucked up.. i have not noticed and change in gas mileage or anything.. have you experianced anything similar???
phbrush
27
Dec 17, 2014 07:25 AM
JoshJosephKeith
May 4, 2009 04:38 PM
CLE
May 28, 2007 10:14 AM
kapoosh valve
23
Jul 1, 2005 09:02 PM
Cutlass355
Apr 30, 2005 03:31 PM
