What other OEM Honda/Acura wheels fit a 5th Gen?
I am trying to pick up a second set of wheels for some snow tires. I want to make sure they fit well with the correct bolt pattern and offset.
Here is what info I have so far
RSX 02+ Should fit fine
S2000 Will not fit
Accord 5 lug ?
TSX, TL ?
Someone please fill in the ? marks if you know.
S2000 Will not fit
Accord 5 lug ?
TSX, TL ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type SH »</TD></TR><TR><TD CLASS="quote">Any rim that has a 5X114.3 lug pattern.
uh not really. rim width and offset matters. For instance you could use S2000 fronts but not S2000 rears.
I've seen RSX, CL Type-S, and Front S2000 rims on Preludes before
</TD></TR></TABLE>uh not really. rim width and offset matters. For instance you could use S2000 fronts but not S2000 rears.
NSX rears will also not fit, NSX fronts will.
I am mainly concerned with offset, because I beleive most Honda 5 lugs are 114.3x5.
If snow tires is what your going for, look into some cheap yet effective 15inch oddessy steelies. Mount some snow tires on there and you got your self a set of cheap snow wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sushiboy »</TD></TR><TR><TD CLASS="quote">97-01(?) CR-V wheels fit.</TD></TR></TABLE>
I second that as I have a spare set of CR-V wheels with snow tyres fitted, and they bolt right on to my 5th gen no probs.
would the search feature not be effective here? i've seen many posts in different forums about correct bolt pattern and offset for the different models....however, to answer your question to the best of MY ability:
5th gen = 5X114.3 E51
most all other hondas i've seen have a significantly lower offset (35-42) but all 5lug hondas should be 5X114.3 (i could be wrong about rarer models)
racecarpete
Jun 4, 2002 09:33 PM
