block gaurd removal
Old Jan 11, 2005 | 09:02 PM
mustbenu's Avatar
Default block gaurd removal
i recently purchased a rebuilt b18c motor
it has a nuformz block gaurd in it......
would i be able to take the head off and just remove the block guard and reinstall the head..
Old Jan 11, 2005 | 10:34 PM
mustbenu's Avatar
Default Re: block gaurd removal (mustbenu)
ttt
Old Jan 12, 2005 | 08:27 AM
civic-4-ges's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustbenu &raquo;</TD></TR><TR><TD CLASS="quote">would i be able to take the head off and just remove the block guard and reinstall the head..</TD></TR></TABLE>
Not if it was installed correctly. If done correctly, then the previous owner would have had his cylinders honed after installing it. The block guards slightly distort your cylinders.
By taking it out, the honing done after the block guard install will actually cause egg shaped cylinders.
However...chances are the previous owner did not do it right, and never honed the walls afterwards. Therefore you should be fine!
boofunit
Jul 31, 2011 11:50 PM
sivtechatchy
Mar 6, 2009 03:45 AM
hmtcrxsir
Mar 25, 2006 04:27 PM
mustbenu
Jan 17, 2005 11:41 AM
Lewcis
Jul 29, 2004 09:19 PM
