swap stumbles then cuts off
Old Jan 11, 2005 | 08:00 PM
highroller420l's Avatar
Default swap stumbles then cuts off
i have a b17 swap into a 92 civic cx. it will start but not all the way then stumble an cut off.
Old Jan 11, 2005 | 08:04 PM
stealth civic's Avatar
Default Re: swap stumbles then cuts off (highroller420l)
Clogged fuel filter, bad ignitor, loose ground, electrical problem, could m=be a million things. We need more details though.
Old Jan 11, 2005 | 08:06 PM
Default Re: swap stumbles then cuts off (stealth civic)
all grounds are there an tight fuel seems to be flowin good the dizzy just came off a running car that spun a rod bearin everthing is hooked up besides the vtec wires an o2 sensor if u need n e more info just ask
Old Jan 11, 2005 | 08:08 PM
JBG's Ferio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller420l &raquo;</TD></TR><TR><TD CLASS="quote">all grounds are there fuel seems to be flowin good </TD></TR></TABLE>
Details like is the engine getting fuel? are all cylinders firing? are all lines and hoses hooked up and in proper location? All grounds connected? Everything wired right? Battery Charged?
Old Jan 11, 2005 | 08:11 PM
Default Re: swap stumbles then cuts off (JBG's Ferio)
Have you checked your timing?
Old Jan 11, 2005 | 08:12 PM
sorry i was tryin to fix the couple of words i had typed but there is more posted above
Old Jan 11, 2005 | 08:14 PM
yeah timing is fine
Old Jan 11, 2005 | 08:31 PM
Take off the distributor cap and see if the screw in the distributor rotor is still there, those have a tendency to some out.
Old Jan 13, 2005 | 06:52 PM
yea that was it i got the dis. off a buddys working car so i didnt think to check an make sure it was all good but thanks for the help
Old Jan 13, 2005 | 06:54 PM
yea that was it the rotor screw gone thanks for all the help
Old Jan 13, 2005 | 09:09 PM
You are welcome, glad to see its running. How does it feel?
Glowicki
19
Jan 2, 2013 08:02 PM
CircuitFG
May 18, 2006 06:55 PM
jDm_jeremy
Nov 18, 2005 04:32 AM
pacifico
Aug 28, 2004 08:37 PM
Civic Hx-T
37
May 3, 2004 10:55 AM
