swap stumbles then cuts off
Re: swap stumbles then cuts off (highroller420l)
Clogged fuel filter, bad ignitor, loose ground, electrical problem, could m=be a million things. We need more details though.
Re: swap stumbles then cuts off (stealth civic)
all grounds are there an tight fuel seems to be flowin good the dizzy just came off a running car that spun a rod bearin everthing is hooked up besides the vtec wires an o2 sensor if u need n e more info just ask
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller420l »</TD></TR><TR><TD CLASS="quote">all grounds are there fuel seems to be flowin good </TD></TR></TABLE>
Details like is the engine getting fuel? are all cylinders firing? are all lines and hoses hooked up and in proper location? All grounds connected? Everything wired right? Battery Charged?
Take off the distributor cap and see if the screw in the distributor rotor is still there, those have a tendency to some out.
yea that was it i got the dis. off a buddys working car so i didnt think to check an make sure it was all good but thanks for the help
Glowicki
19
01-02-2013 08:02 PM
Civic Hx-T
37
05-03-2004 10:55 AM
