99-00 Civic SI tranny problem/question??
Old Jan 11, 2005 | 12:18 PM
b18cx's Avatar
Default 99-00 Civic SI tranny problem/question??
DID A SEARCH, found lots of related articles, but there is no longer any post in the archived topics. Was kinda pissed.
Anyways, have a tranny from a 00 SI that has a high rpm grind when shifting and will pop out of gear when turning a corner. Trying to get an idea of the parts that need to be replaced. Any help appreciated. Bent shift fork, synchro's, retaining clip...????
Before you tell me to do a search, check it out your self, the search will pull up a ton of topics (archived) , but there is no info in the topic, " Error, No post are in this topic".
Old Jan 11, 2005 | 12:36 PM
chad's Avatar
Moderator
Default Re: 99-00 Civic SI tranny problem/question?? (b18cx)
grind= need new syncro's
popping out of gear....need new engine mounts or you have bent shift forks....mostlikely need new engine mounts
Old Jan 11, 2005 | 01:05 PM
dohcdelsol93's Avatar
Default Re: 99-00 Civic SI tranny problem/question?? (chad)
definatly check engine mounts, cheap fix there and very common.
Old Jan 11, 2005 | 01:12 PM
all stock's Avatar
before you even start to drop the tranny, i'd change out the tranny oil and see if that helps.
Harry_Randal
Sep 10, 2004 08:15 PM
drewlee
Jan 8, 2004 09:36 AM
civicudesire
Mar 10, 2003 02:33 PM
krazn
Sep 2, 2002 02:17 PM
