Quick question about headstud torquing...
Old Jan 11, 2005 | 12:18 PM
ScubaStevo80's Avatar
Default Quick question about headstud torquing...
For those that don't know, I recently replaced a blown headgasket on my d15b8 with a y8 gasket. I torqued the head down according to honda-specs but did so with a cheapo torque wrench. At first there was no smoke coming from the exhaust, and now, after about 10-15 miles of around town driving, i'm getting all white smoke again. I did not have the head resurfaced by the way.
I'm getting a better torque wrench this weekend and resurfacing the head, my question is this...
Could it be possible the head is fine and that the bolts backed out or came a bit loose? I'm paranoid about fixing this car and getting it to run for another 10k miles before I do a swap.
Old Jan 11, 2005 | 12:32 PM
civicminded92's Avatar
Default Re: Quick question about headstud torquing... (VolpeOwnsU)
Did you clean the surfaces well?
Also, you do need to check for trueness on head and block - procedure in helms.
Old Jan 11, 2005 | 12:53 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Quick question about headstud torquing... (civicminded92)
D15 motors are notorious for bad head gaskets. You should have checked it for straightness. Its probably warped.
Old Jan 11, 2005 | 01:08 PM
Default Re: Quick question about headstud torquing... (JDM_Ej)
Ok thats what I figured... I put the head back on with a new HG and drove it around for about 5-10 miles and it seemed ok, no white smoke. Then I changed my exhaust and the smoke was coming out a good deal and it was drinking a bit of coolant again.
I'm going to get my head checked in south NJ this saturday.
Joker_God
12
Nov 30, 2009 01:34 PM
crxboy909
23
Aug 4, 2009 06:07 PM
DS_Vtec
Nov 18, 2007 08:08 PM
n00b
May 20, 2005 12:49 AM
zerofighter777
Aug 10, 2002 07:12 AM
