Oxygen Sensor
Old Jan 11, 2005 | 09:16 AM
CassieCivic99's Avatar
Default Oxygen Sensor
I've searched everywhere for the answer to this quesiton and can not find the answer. I have a 99' Civic Si and recently purchased a Bosch Universal Oxygen Sensor. The only problem is I do not know the wire conversion. The instructions ahve OE sensor types, but I do not know what kind of OE sensor I already have (stock). If anyone could help me with this problem, it would be appreciated. Thanx.
Old Jan 11, 2005 | 09:29 AM
colinproctor's Avatar
Default Re: Oxygen Sensor (CassieCivic99)
you have a four wire exhaust O2 stock. you also have 2 sensors for that car, one for the exhaust and one for the intake. not sure if thats what you wanted to know.
Old Jan 11, 2005 | 09:38 AM
Ricey McRicerton's Avatar
Default Re: Oxygen Sensor (FdOoUoRr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FdOoUoRr &raquo;</TD></TR><TR><TD CLASS="quote">you have a four wire exhaust O2 stock. you also have 2 sensors for that car, one for the exhaust and one for the intake. not sure if thats what you wanted to know.</TD></TR></TABLE>
Actually you have two 02 sensors in your exhaust. One pre catalyst, and one post catalyst.
Old Jan 11, 2005 | 09:40 AM
Default Re: Oxygen Sensor (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Actually you have two 02 sensors in your exhaust. One pre catalyst, and one post catalyst.</TD></TR></TABLE>
forgot about that, your right.
Old Jan 11, 2005 | 09:42 AM
I'm not sure what the color conversions are for the wires. I have four wires for my stock O2 sensor and 4 wires for my bosch o2 replacement sensor. The instructions have a chart listing the types (A,B,C,D) of OE sensors and the color conversion for the Universal O2 sensor. I do not know what type (A,B,C,D) or O2 sensor I currently have to figure out the coversion chart. I believe I have a Type C Stock O2 sensor, but I am not sure. If someone could confirm this, I can connect the correct colored wires.
Old Jan 11, 2005 | 09:46 AM
DaX's Avatar
DaX
Loved
Community Favorite
The wire functions are listed in the knowlege base. Search for 'oxygen sensor.'
Old Jan 11, 2005 | 09:47 AM
IVI's Avatar
IVI
Old Jan 11, 2005 | 09:50 AM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CassieCivic99 &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure what the color conversions are for the wires. I have four wires for my stock O2 sensor and 4 wires for my bosch o2 replacement sensor. The instructions have a chart listing the types (A,B,C,D) of OE sensors and the color conversion for the Universal O2 sensor. I do not know what type (A,B,C,D) or O2 sensor I currently have to figure out the coversion chart. I believe I have a Type C Stock O2 sensor, but I am not sure. If someone could confirm this, I can connect the correct colored wires.</TD></TR></TABLE>
we can't confirm it unless you tell us what the "types" are. i've done a bosch universal for my car b4. btw, denso direct fit 02 sensors are only $60 on ebay (same price as bosch universals in the store). tell us what each "type" is and we can match it for you.....
Old Jan 11, 2005 | 09:52 AM
dantastic's Avatar
Default Re: Oxygen Sensor (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
wow. not a very helpful diagram... it doesn't say which color is on the harness or the sensor (or for what brand of sensor)
Old Jan 11, 2005 | 10:09 AM
Default Re: Oxygen Sensor (dantastic)
I believe I found the answer in the archives. I was only searching in the recent topics. I believe the wiring goes like this:
OEM/Bosch
Black=White Heater wire
Green=Grey Send wire
White=Black Receive wire
I appreciate everyone's quick responses! This website is very helpful.
I purchased a Bosch Premium (right) Universal O2 Sensor part #15733 (Supposedly made to use in my car (99' Honda Civic Si)). I believe my car uses OEM Sensor Type C because it was the only one that mentioned using a green ground wire. Thanks again.
Old Jan 11, 2005 | 10:50 AM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CassieCivic99 &raquo;</TD></TR><TR><TD CLASS="quote">I believe I found the answer in the archives. I was only searching in the recent topics. I believe the wiring goes like this:
OEM/Bosch
I purchased a Bosch Premium (right) Universal O2 Sensor part #15733 (Supposedly made to use in my car (99' Honda Civic Si)). I believe my car uses OEM Sensor Type C because it was the only one that mentioned using a green ground wire. Thanks again.</TD></TR></TABLE>
sounds pretty good
Old Jan 11, 2005 | 03:26 PM
IVI's Avatar
IVI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">
wow. not a very helpful diagram... it doesn't say which color is on the harness or the sensor (or for what brand of sensor)</TD></TR></TABLE>
its for bosch or an oem honda sensor.
its a very helpful diagram just not a masterpiece.
it shows you BOTH the colors on the harness and the sensor depending on how your holding either.
Even if the colors were all the same like on my harness, it still shows you which wire goes where on the sensor.
sorry its not good enough for you but it fixed my oxygen sensor.
Old Jan 11, 2005 | 04:08 PM
99hatch's Avatar
that pic looks fine to me. whats wrong with it?
maybe you cant read and/or you prefer colors to words?
EnSAn
May 6, 2006 10:40 PM
importnoodles
May 22, 2005 08:11 AM
djnikko
Sep 8, 2003 12:44 AM
EK45VTi
Jul 31, 2003 12:47 PM
