4 lug to 5 lug civic
if your going to change from a 4 to a 5 lug you have to change your hub out but you also have to see if you can find a hub that will fit with the baring that your car uses.. then once you find the right hub then make shure the spline is right for the axles your using.. to be onest with you buy the 5 lug set up or do some research on it more. it can be done....
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khmershadow »</TD></TR><TR><TD CLASS="quote">theres no way to change 4 lug to 5 lug by changin the rotor? </TD></TR></TABLE>
Why do u want to go 5 lug?
If you want bigger rotors.... http://www.fastbrakes.com
I think he wants the lug judging from his wording. Apparently an extra lug = cool.
If you want to build a show car, I just made a How-to on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khmershadow »</TD></TR><TR><TD CLASS="quote">im thinkin about using accord or prelude 5 lug to fit in a civic </TD></TR></TABLE>
wtfh?
wtfh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">
wtfh?</TD></TR></TABLE>
weeeeeeeeeeeeee!
weeeeeeeeeeeeee!
importboi22
Sep 25, 2006 04:44 PM
