max temp safe for jb weld?
I'm not sure of a number, but I can say that I used it to patch holes in an exhaust manifold cover (also used as heater) for a VW bug...and it all burned off and really smoked up the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Want2race »</TD></TR><TR><TD CLASS="quote">The Rx-7 guys use it in their engines.. So 1800 degrees F isnt hurting it! They last too!</TD></TR></TABLE>I can't say that I agree with this. The heat of cumbustion may get that hot, but the engine does not. How do you figure that their engines are getting 1800 degrees?
Aluminum melts at 1218 degrees F
http://www.onlinemetals.com/meltpt.cfm
or grape fruit
or grape fruit
1800 is what I heard from an engine rebuilder.. Thats the temp @ exit of exhaust since its a turbo chrager.. So lets just say its getting fucckin hot in the combustion chamber!
Q: How much heat can J-B Weld withstand?
A: J-B Weld (Part # 8265-S, 8265, and 8280) can withstand a constant temperature of 500 degrees F. The maximum temperature threshold is approximately 600 degrees F for a short term (10 minutes).
http://jbweld.net
http://jbweld.net
98vtec
21
Jan 10, 2007 03:17 PM
1.8
Welding / Fabrication
Mar 4, 2005 03:38 PM
JDMlyfestyle
48
Nov 3, 2004 05:29 AM
