Sensor on b17a
Old Jan 11, 2005 | 07:17 AM
Jdmglenn's Avatar
Default Sensor on b17a
if the knock is the one by the deck surface on the number 2 cylinder , what is the green sensor by the oil filter?? its like RIGHT next to the oil psi sensor???
any help is appreciated
Old Jan 11, 2005 | 12:09 PM
AL ASPIRATED's Avatar
hrmmm how many wires?
Old Jan 11, 2005 | 09:04 PM
PrettyLude's Avatar
post up a picture
Old Jan 11, 2005 | 09:39 PM
Jdmglenn's Avatar
has two wires , ones white and ones black i THINK, i have no digi cam guys sorry im broke lol
Old Jan 12, 2005 | 02:24 AM
slomofo's Avatar
GDD Member
Does it look exactly like the knock sensor, but sits lower near the oil filter and has a green plug? Other h-t people have told me that it was a second coolant temp sensor, but when I removed mine, there was oil in the hole.
Old Jan 12, 2005 | 06:57 AM
Jdmglenn's Avatar
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">Does it look exactly like the knock sensor, but sits lower near the oil filter and has a green plug? Other h-t people have told me that it was a second coolant temp sensor, but when I removed mine, there was oil in the hole.</TD></TR></TABLE>
EXACTLY , its like mounted in the middle of that GOLD nut and i removed mine as well but there was oil on it ????
i still dont know what this is
Old Jan 12, 2005 | 02:38 PM
Jdmglenn's Avatar
bump
Old Jan 12, 2005 | 07:42 PM
acy76's Avatar
Default Re: (JdmGlenn)
I had trouble figuring this one out a while back -- was installing an Endyn breather kit, and they didn't know what it was for either, just that it had to come out...
That sensor trips the AC fan when the car is off and the oil temp reaches a certain point. It will run for 15 mins. or so. It's only found on the 2nd generation Integras; later engines have a plug there, just like on the other (passenger) side of the block.
The info is in the Helm manual, buried somewhere in the electrical section if you care to look it up.
FYI, the part # on that sensor is the same as the coolant fan switch on later b-series engines -- the one on the thermostat housing, if I recall.
Old Jan 12, 2005 | 07:51 PM
Jdmglenn's Avatar
Default Re: (acy76)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acy76 &raquo;</TD></TR><TR><TD CLASS="quote">I had trouble figuring this one out a while back -- was installing an Endyn breather kit, and they didn't know what it was for either, just that it had to come out...
FYI, the part # on that sensor is the same as the coolant fan switch on later b-series engines -- the one on the thermostat housing, if I recall.</TD></TR></TABLE>
THANK YOU SOOOOO MUCH ...........I LOVE HONDA TECH
skimb37
Jan 1, 2009 08:31 PM
EK k kay
23
Jan 16, 2005 05:34 PM
CaptivaBlue
Oct 6, 2004 03:27 PM
LudeyKrus
Apr 7, 2003 08:20 PM
Prevail
Feb 13, 2003 09:25 PM
