Mini-me odb2 y8 head/ecu to odb1 cx question
Old Jan 11, 2005 | 06:58 AM
ScubaStevo80's Avatar
Default Mini-me odb2 y8 head/ecu to odb1 cx question
Here's a question I couldnt find a definitive answer to. I also am finding that search doens't work today or I would have looked harder. I have the ability to pickup a low mileage 97 y8 head and ecu. Includes both manifolds, TB, all sensors and dizzy.
I want to use this for my 95 cx but am wondering if it would be a huge pain because of the diff in obd1 vs obd2? Do I need new injectors, extra o2's etc or should I just look for a z6 head?
Bauley or any other mini-me experts feel free to chime in...
Old Jan 11, 2005 | 07:22 AM
shifty35's Avatar
Default Re: Mini-me odb2 y8 head/ecu to odb1 cx question (VolpeOwnsU)
Probably the easiest way would be to use the Y8 head and distributor and stock intake manifold... if the Y8 manifold was from a manual, it may work, I'm not sure about the wiring. You definitely will have to rewire for the OBD2 distributor. You should also use and OBD1 P28 ECU, as the P2P will be exceptionally difficult (read next to impossible) to make work.
Old Jan 11, 2005 | 09:20 AM
colinproctor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VolpeOwnsU &raquo;</TD></TR><TR><TD CLASS="quote">I want to use this for my 95 cx but am wondering if it would be a huge pain because of the diff in obd1 vs obd2? Do I need new injectors, extra o2's etc or should I just look for a z6 head?</TD></TR></TABLE>
b7 OBD1 dizzy works in a y8 head. that solves the OBD2 to OBD1 problem. pretty sure your stock injectors work also, not positive though.
Old Jan 11, 2005 | 09:38 AM
Default Re: Mini-me odb2 y8 head/ecu to odb1 cx question (FdOoUoRr)
Bauley says use the y8 head, cx (d15b8) dizzy, and a obd1 p28 ecu...
So basically I should ...
Use the y8 head, but use my cx injectors/clips/etc, use an odb1 distributor (y7, y8 or z6?) .
Can I use the y8 inake mani and swap sensors? Or will the odb2 sensors that are already on it work fine?
Super Chicken
Mar 7, 2005 06:15 PM
simplegreenmachine
13
Aug 4, 2004 04:43 AM
Rydaddy
Nov 2, 2003 04:27 PM
SOHC_MShue
Oct 13, 2003 07:28 PM
Ya@inlinePRO
Oct 28, 2002 08:46 PM
