ABS on 96 coupe
Old Jan 10, 2005 | 11:09 PM
ngq's Avatar
ngq
Default ABS on 96 coupe
This weekend iam attempting ABS installation in my civic. I know its not easy and
i could stay without a ride for few days.
I have a jdm civic SIR (RH) Which i will take all i need (interior wire harnes,ABS ecu,ABS pump,front end wire harness..etc.) .From what i can forsee its strait forward procedure hope for no surprises.
Has anybody attempted ABS installation & is it worth all the work.
My coupe has itr 5 lugg conversion.
you input is appreciated.
Old Jan 10, 2005 | 11:19 PM
SOHC4life 96's Avatar
Default Re: ABS on 96 coupe (ngq)
From what I've seen its not worth it at all. You do know you have to change ALL the hard lines that go throughout the car as well dont you? I think it's just a major waste of time and money for the results, but if you really want it have it, I say go for it. Good luck.
Old Jan 10, 2005 | 11:58 PM
ngq's Avatar
ngq
Default Re: ABS on 96 coupe (SOHC4life 96)
Thank u for response, All i need is available & its free All i pay for is some labor &
brake fluid.
I even got itr ABS proportioning valve to accommodate the 5lug conversion.
In Jordan most cars com without ABS so junk yards just through them away.
Old Jan 11, 2005 | 12:21 AM
dantastic's Avatar
your car is also RH right? the brake lines will be copletely different for LHD and RHD, as will the wiring harnesses for the ABS computer. don't forget the appropriate front axles with the ABS sensor ring on them
Old Jan 11, 2005 | 12:28 AM
ngq's Avatar
ngq
Default Re: (dantastic)
Good observation dantastic,my car is LH but the only lines i change are running from the ABS pump to brake master cylinder.
j_dee1st
Jan 18, 2009 09:11 PM
spaceman00
13
May 2, 2007 08:53 AM
sPaRk'iT
Nov 16, 2004 11:56 PM
highcomp
Apr 15, 2004 07:36 PM
Boostage
Dec 10, 2003 04:25 PM
