camber kit
Old Jan 10, 2005 | 09:57 PM
vdub08's Avatar
Default camber kit
hey guys, i searched this, found the topics but for some reason, it came up with no posts?
i need some suggestions for a decent camber kit, cuz im running ls meshes on a 195/55/15 tire and im still rubbing.
god dam my car is low....but i dont have money for new sus either so help me out
ps. how do camber kits work? and is it hard to install?
Old Jan 10, 2005 | 10:01 PM
SjCiViCHB's Avatar
Default Re: camber kit (tofu9000)
camber keeps adjust the car's camber... when your wheel is like this /-----\ its negative camber. Thats usually what happens when your lowered, and you unevenly wear out the inner side of your tire. \----/ if your wheels are like taht you have positive camber. Now getting a camber kit helps you striaighten those wheels to the correct spec's so you can get even wear or less negative or positive camber. Also be sure to get an alignment to correct specs also.
Old Jan 10, 2005 | 10:04 PM
mrdanglez's Avatar
Default Re: camber kit (SjCiViCHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SjCiViCHB &raquo;</TD></TR><TR><TD CLASS="quote">camber keeps adjust the car's camber... when your wheel is like this /-----\ its negative camber. Thats usually what happens when your lowered, and you unevenly wear out the inner side of your tire. \----/ if your wheels are like taht you have positive camber. Now getting a camber kit helps you striaighten those wheels to the correct spec's so you can get even wear or less negative or positive camber. Also be sure to get an alignment to correct specs also.</TD></TR></TABLE>
so are you saying that tofu9000 does or does not need a camber kit???
Old Jan 10, 2005 | 10:33 PM
sohcvtec1995's Avatar
If your tires are rubbing without a camber kit, then it will get worse when you do get one. I would just save and get coil overs that way you can raise your car up, and then get a camber kit. I always recommend one, cause i know that it works great on saveing tires.
Old Jan 10, 2005 | 10:38 PM
mrdanglez's Avatar
Default Re: camber kit (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">If your tires are rubbing without a camber kit, then it will get worse when you do get one. I would just save and get coil overs that way you can raise your car up, and then get a camber kit. I always recommend one, cause i know that it works great on saveing tires.</TD></TR></TABLE>
kool
Old Jan 10, 2005 | 10:41 PM
vdub08's Avatar
hmm what spring+stut combo should i save for then???
cuz im low on cash i'd rather just put together a combo to save a bit or get more outa my money
Old Jan 10, 2005 | 10:56 PM
Default Re: (tofu9000)
Just get some coilovers. That way you can adjust everything to your likeing. Or you could get some Koni yellows, and just adjust the height slightly at the expense of ride quality. Me personally would just get some Kyb's and some Arospeed coilovers and go from there, that way you have a option on ride height and stiffness.
Old Jan 10, 2005 | 10:57 PM
=GAME='s Avatar
how low are we talking bout here 2''+?
rubbing only occurs when you turn and lock the wheels right?
Old Jan 10, 2005 | 11:01 PM
vdub08's Avatar
Default Re: (=GAME=)
yea its a 2"+ drop. and i only heard the rubbing on my 205/40/17s, but not the meshies. but the vibration i get driving the car is what i thoguht to be the gradual camber wear
Old Jan 10, 2005 | 11:04 PM
=GAME='s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tofu9000 &raquo;</TD></TR><TR><TD CLASS="quote">yea its a 2"+ drop. and i only heard the rubbing on my 205/40/17s, but not the meshies. but the vibration i get driving the car is what i thoguht to be the gradual camber wear</TD></TR></TABLE>
first off are those 17's the right offset for the car? im running 17x7 on my eg hatch with no rubbing.
also vibrations could be caused by those wheels being unbalanced and your car not align right.
raise it back to around 2", get those wheels balanced and car align, then see how it rides after.
Old Jan 10, 2005 | 11:08 PM
vdub08's Avatar
thanks man, now its just to get my bank account out the red and save up for some coilovers!
Old Jan 10, 2005 | 11:09 PM
=GAME='s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tofu9000 &raquo;</TD></TR><TR><TD CLASS="quote">thanks man, now its just to get my bank account out the red and save up for some coilovers!</TD></TR></TABLE>
...and an alignment. i seen tires go bad within 3 months with bad camber and toe.
Old Jan 11, 2005 | 04:29 PM
SjCiViCHB's Avatar
Default Re: camber kit (mrdanglez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdanglez &raquo;</TD></TR><TR><TD CLASS="quote">
so are you saying that tofu9000 does or does not need a camber kit???</TD></TR></TABLE>
well it really depends where his tires are rubbing, but looks like the question was answered already.
Old Jan 11, 2005 | 04:38 PM
green-'s Avatar
An alignment is always the first thing on my mind after doing suspension work. Definitely get one as soon as you can after installing your coilovers, or whatever your going to use.
Old Jan 11, 2005 | 04:50 PM
Just get some arospeed ones they are like 120 bucks at most. at least thats what i paid for mine 4 years ago
BJA86
11
Sep 2, 2007 01:00 PM
AZNBIGPIMPN505
18
Jan 7, 2005 10:43 AM
Kyles ej1
26
Nov 19, 2004 06:09 AM
jdmrealm
Nov 28, 2001 11:29 PM
ALF
Aug 16, 2001 05:47 PM
