new ground on battery and lights are dimming ?
Old Jan 10, 2005 | 07:44 PM
superhatchbackbros's Avatar
Default new ground on battery and lights are dimming ?
i just put a new ground on my battery to my frame and i started my car it was running ok and then it started to dimm the lights in and out i aslo dont have a ground on the front of the motor to the frame near the lights on my 90 civic hb you know the one on the right side that goes to on ur valve cover i was thinkin that is part of my problem but not sure . if u got any answers let me know ... jason&jesse...
Old Jan 10, 2005 | 07:46 PM
eda6's Avatar
Default Re: new ground on battery and lights are dimming ? (superhatchbackbros)
Add another ground from the valve cover to frame and see if your problem is corrected.
Old Jan 10, 2005 | 08:23 PM
Louie B.'s Avatar
The valve cover ground doesn't work very well on it's own. you need to go from the frame(where you just mounted your battery ground) to the Tranny (clutch cable bracket)
shawn69
Apr 2, 2009 09:00 AM
90YellowRex
Jan 22, 2006 08:35 PM
Krnbk2
May 30, 2004 06:11 AM
Superhatch
Feb 13, 2004 04:22 PM
_jester_
Dec 13, 2003 11:20 AM
