Y8 tranny on Z6 Del Sol engine
If I were to bolt on a D16Y8 tranny to my D16Z6, is that all I really have to do? Or am I going to need to get a new clutch kit, and other things as well? I get a new tranny SOON, and figured I might as well upgrade a little if I can.
No, ALL D-Series clutches/flywheels are interchangeable. All D-Series transmissions are direct bolt-in with D-Series blocks.
But, since the transmission is out, you might want to change out a few things that wear and tear over time. Main seal and Input Shaft Bearing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">No, ALL D-Series clutches/flywheels are interchangeable. All D-Series transmissions are direct bolt-in with D-Series blocks.
But, since the transmission is out, you might want to change out a few things that wear and tear over time. Main seal and Input Shaft Bearing.</TD></TR></TABLE>
what he said
Mr.F
Feb 21, 2012 07:21 PM
CaptinMcnut
14
Nov 24, 2004 11:07 AM
