new suspension bumpy harsh ride agx ground control
Old Jan 10, 2005 | 05:00 PM
crxsiperf's Avatar
* B A N N E D *
Default new suspension bumpy harsh ride agx ground control
Im still fighting with my new suspension setup on my 94 civic hatch , i have agx struts the whole way around and ground control coilovers , when i am going down the highway the car bounces alot , makes my head bob all around and really feels like crap , its rather harsh on bumps and differences in where roads meet up and whatnot. Im sure lots of other peeps have this setup , did yuens have any similar problems , i tried all different settings on the struts as well , any input much appreciated.
Old Jan 10, 2005 | 05:32 PM
jlacoy82's Avatar
71.192.16.183
What spring rates are you using?
Old Jan 10, 2005 | 06:07 PM
ironlung78's Avatar
Default Re: new suspension bumpy harsh ride agx ground control (crxsiperf)
i read this post to my girl and her words exactly....
"welcome to the world of lowered cars"
if she can deal with it so can you, trust me....
Old Jan 10, 2005 | 06:08 PM
JDM-97CX's Avatar
Live with it. If you don't want to live with it put the stockers back on. Simple as that.
Old Jan 10, 2005 | 06:21 PM
silentkill03's Avatar
what setting are the shocks at?
Old Jan 10, 2005 | 06:28 PM
snoochtodanooch's Avatar
Default Re: (silentkill03)
damn lowered cars. Kids and this rap music.... sooo young.....sooo angry
Old Jan 10, 2005 | 06:55 PM
NINJASPY's Avatar
Default Re: (snoochtodanooch)
sounds like either you are too low and your shocks/springs are too soft. Stiffen the shocks. and if you have standard ground controls, check your springs and make sure you have the stiffer ones in the front, if they are too soft they will just move too much and bottom out.
Old Jan 10, 2005 | 07:13 PM
doughboy_88's Avatar
actually, if he bounces a lot, it sounds like the struts are over-dampened when used in combo with the GC's.
Old Jan 10, 2005 | 07:55 PM
EG_intheworks's Avatar
Default Re: (doughboy_88)
I have the same set up, on the 1 setting on my agx they ride smooth, for the dumper hatch, how low are you? If you are super duper dumped the shocks might not have enough travel thus giving you a harsher ride. Give yourself a little wheel well clearence and give the shock some room to move if thats the case.
-also how do you tell which springs are for front or back? I dont think i even looked i just threw that **** on
Old Jan 10, 2005 | 08:26 PM
Touch's Avatar
Default Re: (EG_intheworks)
also... not to sound like an ***, but did you install them properly? I had a friend who had the same setup and when he first put his on they bounced like a deranged bobble head, and that was cause he didn't cut the bumpstops. So my advice is to retrace your steps and make sure you did em right.
Old Jan 10, 2005 | 08:30 PM
NINJASPY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG_intheworks &raquo;</TD></TR><TR><TD CLASS="quote"> -also how do you tell which springs are for front or back? I dont think i even looked i just threw that **** on </TD></TR></TABLE>
look at the numbers on the spring, if you have stock gc's, they usually come with 350/250lbs or 64/44kg.mm, something like that. theres 3sets of numbers, 1 for spring lenght, one for spring inner diameter and one for spring rate. my friend put on his gc/agx on and was wondering why he kept on bottoming out aka "rather harsh on bumps and differences in where roads meet up" he had the boucing problems too, but we switched the springs and now he loves his setup
Old Jan 13, 2005 | 05:58 PM
crxsiperf's Avatar
* B A N N E D *
Default Re: (NINJASPY)
My srpings rates are as follows , front ones are 200.64.58 and the rears are 180.64.44 , and when i installed everything i used the washer that goes under the top had instead of the brass collar that came with the struts , would that affect anything &gt;? Also i cut the bumpstops as the ground control showed , does anyone have an exploded pic or real pic of this setup put together off the car showing a detailed pic of it complete. the ride is terrible , and its lowered a tad under stock ride height and i have them damping set to 4 on front and back , the softer setting seemed worse.
Old Jan 15, 2005 | 06:07 PM
crxsiperf's Avatar
* B A N N E D *
Default Re: (crxsiperf)
Bump
cmon i need some advice here
Old Jan 15, 2005 | 06:09 PM
civictildeath's Avatar
try the suspension forum
Eg6Matt
Feb 14, 2010 08:31 PM
mister_ej1
32
Mar 22, 2007 10:53 PM
STNDOUT
Jul 31, 2005 04:38 PM
-Whitey-
17
Dec 5, 2002 10:44 PM
tolowhb
Sep 12, 2002 09:15 PM
